Question about Streamlight Survivor LED Flashlight, by 90503
Streamlight survivor switch
Replacement switch
Find replacment switch
Streamlight might be able to supply the part or information.
May 10, 2014 | Streamlight Survivor LED Flashlight, by ...
Streamlight pro tac 2L wont turn on
You are not alone with this problem, it appears to be a failing on both this and other models. I would contact Streamlight and let them know. Their customer service email address is cs@streamlight.com
Jan 04, 2014 | Streamlight Flashlights Streamlight Pro...
My base broke and need a replacement pin to hold it back into place? dont have a manual looking for part numbers
Are you aware of saffordgoods.com, they have best collection of streamlight flashlights and their accessories. you can order online it self.
Sporting Goods Outdoor Gear and Sporting Goods Store
Feb 25, 2011 | Streamlight Survivor LED Flashlight, by ...
I have a Streamlight Strion Xenon compact flashlight that has served me well for two years. Recently the 'twist to stay on' feature has failed. The 'push the tailswitch on' feature is still functioning,...
Ray, sounds like the switch has a problem. Streamlight is usually really good about fixing things. If you can drop by a Stream retailer in your area, they will probably give you a new tail cap. Or contact STREAM directly.
One thing, when you screw the tailcap tight, does the light come on? I have a SUREFIRE that does that, but I dont have a twist on Streamlight.
Sep 27, 2009 | Streamlight Strion 12V DC Only
Flashlight problems
streamlights have lifetime warranties. Contact them to find a dealer that can fix it. They might even let you send it in to get fixed.
Aug 15, 2009 | Streamlight Stinger XT DC, Black
Rechargable Stinger new bulb is dim orange
Could possibly be a bad switch, I would also get that battery tested out also. If you still have a receipt it should be covered under warranty. If not try sending it in anyway. Limited lifetime warranty does not include bulb, or batteries but, anything else on that Stinger should have a lifetime warranty. Of course that excludes abuse. Check out the website www.streamlight.com and go to FAQ for a nearest Authorized Service Center or send it directly to Streamlight. Address also listed on the website. Hope that helps ;)
Jul 03, 2009 | Stinger Streamlight XT Rechargeable...
Streamlight stinger not bright
No! the last thing you want to do is get another light, if this light is still in top shape I suggest you send it back to Streamlight for warranty repair. Lifetime warranty on the light alone as far as the battery goes if you're getting an authentic Streamlight Rechargeable battery there shouldn't be a problem. If it's a knock-off battery you're on your own. Check this website out www.streamlight.com send it back to the address in contact or find an Authorized service center in your area. From what you're telling me here I honestly think it's a bad battery, I could be wrong it may be a bad switch. The switch is covered under a lifetime warranty. So take advatange of it while you can! ;) hope that helps.
Jan 24, 2009 | Stinger Streamlight 75000
Wont recharge
Right were the pluge is on the charger is it clean and check the light see if the pluges are clean if not just clean them with a soft rag
Aug 07, 2008 | Stinger Streamlight 75000
Switch replacement instructions
You have to push the light down from the long rod you have there while compressing the two grids with a needle nose plier. The switch should be able to slide right out that is if it's a black switch. However...if you have the older version of the switch module that either has a clear/beige switch or clear beige/cream switch you need to bang that ****** out. Try not to hurt yourself because this can get a little tougher and may take a couple of practice to actually get that switch out. If all else fails send it back to Streamlight repair department. It's covered under lifetime warranty you know ;) www.streamlight.com follow the contact section and the addy's there. goodluck
Jul 09, 2008 | Stinger Streamlight 75000
Streamlight Survivor LED Flashlight,  by  90503 Logo
50 people viewed this question
Top Streamlight Camping, Backpacking & Hiking Experts
Stan Ford
Tom Chichester
Are you a Streamlight Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
