Question about GE GTWN3000MWS Washer
Washer draining water as soon as you start it
Dishwasher starts program, then few mins in pause/start button flashes "insufficient water supply". Checked all hoses and all clear. Anyone? Thank you. Glen
As soon as the waser begins the wash cycle pause, open door record water level in sump.
Close door and continue cycle until machine faults and stops.
Open door, record water level in sump.
Compare before and after. If level is low that the flapper valve that allows the water to drain is stuck open and the water is draining into the sink as the unit is washing.
To confirm, if the washer drain hose is connect to the neck of the disposal or sink drain, observe the drain after restarting the wash cycle from the beginning. If water is trickling out from the dishwasher while it is washing then it is confirmed the drain door is not closed if equipped with that configuration.
All washers have a process and hardware to drain. Some have a sepperate drain pump
Hope thisd helpd?
Jun 29, 2017 | Dishwashers
How do I replace the water pump
Not enough information, are you stating when you start the cycle no water enters the tub?
The normal operation at start the washer goes into drain first then starts the cycle.
Jan 07, 2015 | Samsung DMT300RFS Dishwashers : Built in...
My Sears Limited Edition washer starts the drain pump as soon as you turn it on and the pump keeps running continuously(I can hear it) which doesn't allow the water to fill the tub?As soon as it start
check the drain hose,if it's pushed down the stand pipe to far it will cause a syphoning affect and drain the water out as fast as it goes in,also have you unplugged the washer to reset the computer board?if not unplug it for 5 to 10 minutes,plug it back in and see if it resets itself,any error codes coming up?let me know how you make out.
Dec 14, 2014 | Washing Machines
LG WM2277H Front Load Washer drain pump never stops
Could be the water pressure switch is faulty and/or the electronics control circuitry.
Suggest you called a qualified Technician to fix it. It will be worth it for many reasons.
Poppa
http://www.cdbaby.com/cd/poppamadison
Mar 23, 2012 | LG WM2277H Front Load Washer
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
My Danby washer always drain the water when it fill the water up on the 3 and 4 water level setting. So I can't wash clothing at all. Hope get answer soon.
The answer is the drain hose. It must be routed higher than the machine or water will always drain. There is no actual drain valve.
Oct 07, 2010 | Danby DWM99W Top Load Washer
Water is draining out the bottom as soon as it
A HOSE CAME OFF--THE DRAIN HOSE HAS A CRACK IN IT-- THE OUTER TUB IS PLASTIC SO IT COULD HAVE A HOLE IN IT---THE DRAIN PUMP IS LOCATED FRONT BOTTOM OF YOUR MACHINE IT COULD HAVE WORN A HOLE IN IT (PLASTIC ALSO)
Oct 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Apr 02, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washer will not fill with water
Is your drain hose lower than the top of the cabinet?? The curved part of the drain hose needs to be slightly higher than the top of the cabinet. Also, the drain hose must have an air gap around it where it goes into the house drain. It sounds to me like your washer is syphoning water out through the drain hose as it is trying to fill. Hope this helps..............
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
GE GTWN3000MWS Washer Logo
14 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
