Question about Symphonic Audio Players & Recorders
How to remove a stuck disc holder from a symphonic 3000a cd player
3 Suggested Answers
  • 4234 Answers
SOURCE: onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
Posted on May 07, 2008
Mini cooper radio quit , fuses not blown
IF you used a knife to attempt to remove the second cd that was stuck and the blade went UNDER the cd, it might have hit the the head of the cd player and shorted something out. IT might have also cause the head to be jammed and it wont move. The only thing that you can do now is remove it.
Mar 23, 2014 | 2006 Mini Cooper
My cd player is stuck unable to remove 12 disc holder
Unplug power source and wait a minute. Hold the eject button while plugging in the fuse or cable. It should eject.
Aug 20, 2013 | 1997 Toyota Avalon
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
A dvd is stuck the door wont open
Remove the top cover.
There will be several screws holding the top on. Remove all and slip the top cover backward to remove.
This will expose the internal system. You will see the disk inside under the laser disk reader.]
You will see a gear the drives the sliding disk holder/loader. This is the part you see come out of the door onto which you place the ****. Roll the gear with your finger and the holder will move. Keep going and the disk will come out as normal. Remove the disk and try to plug the unit in and press the close button. The unit may close as per usual. If not rotate the gear again until the holder goes full back inside. Again try to plug in and press open. It may start working. If not is had problems.
Hope this helps
Mar 08, 2010 | Symphonic WF803 DVD Player/VCR
My jensen touch screen cd/dvd player ate my dvd the longest yard lol. How do i remove the cd from inside the cd player without messing it up?
Turn the thing off, FIRST(!) (please). In the front of the CD holder (in the plate on the front of it) there should be a tiny hole, literally about 1mm diam. Get a paper clip, straighten it out, and then turn the end half-inch/cm over so that it acts as a handle. Now carefully push the other long straight end into the hole (possibly an inch or more), until it contacts something solid. Push it firmly but carefully and the CD holder should slide out. You may need one or two tries at this, but you should be able to do it without too much trouble. This is a recognised method of removing a stuck disc.
Dec 01, 2009 | Computers & Internet
Stuck disc in JVC CD player
It wasn't a car cd player, but a component for a stereo.  I took off the case and shook the player until the disc dropped out.  We plan to replace the player, so no further help is needed.  Thank you for getting back to me so quickly.
Jan 11, 2009 | JVC AM FM CD DET FACE CAR STEREO
Getting ERR message on CD Player
My kids always cause this one ! Switch off power, remove cover. Remove four screws holding top black plastic disc cover and then remove all of the black plastic ( x 7 ) disc holders. You may find that the aluminium cross structure has come adrift. Replace into the slots again and replace all the disc holders. If you want, you can check before replacing cover, by then ejecting and 'disc skipping'. It should thne be ok. If it has been forced, the aluminium cross structure thing may have also come out of the slot it should in in on the right hand side. Slide the disc frame in or out until it can be fitted and retest.
Jan 14, 2008 | Teac PD-H570 7-Disc CD Changer
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
46 people viewed this question
Top Symphonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Symphonic Audio Player and Recorder Expert? Answer questions, earn points and help others
