Question about Philips Televison & Video
How do I tech. support for my phiilips flat screen will
MODEL 50PF963DA\37 NEED TECH. SUPPORT PLEASE TV BEEN DOWN FOR TWO MONTHES STUCK ON MENU SETTINGS SCREEN. WILL NOT EXIT. HELP
SOURCE: emerson remote control with vizio 37" tv
Try 004, it worked for me
Posted on Jan 08, 2009
  • 8 Answers
SOURCE: magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Posted on Oct 13, 2009
tlm931
  • 273 Answers
SOURCE: My Phillips Plasma tv MENU pops up unasked and obscures screen.
there is a soft ware upgrade for that problem on there web site you can down load it to a thumb drive and upgrade your set
Posted on Oct 31, 2009
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
Here is a photo of the board where I have removed the two from my TV. You can see the two open holes.
Posted on Dec 12, 2009
yammy_alf
  • 666 Answers
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
My dvd is stuck I can't change back to Tv mode
take out the plug and try it again if that does not work take it to a tech the chip is faulty.good luck.
Jun 06, 2007 | Mintek DTV-373-D 37 in. LCD HDTV
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers ยท Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
How do I turn off the tv speakers on a Magnavox LCD 47MF437B/37
That's part of setup. Go back to your setup routine (the menu that displays on the screen) and select SPEAKERS OFF
Dec 11, 2012 | Televison & Video
New 37 in. tv conn. to cable not hdtv i have approx a 4" black band on each side and 2" band top & bottom is this a setting issue or because i don't have the hdtv box?
According to all the tech sheets I can see, this unit has no Tuner. If your using the cable box to change channels it probably doesn't support HDTV, except maybe for the individual channels. You might be able to access your TV's on-screen menu to change the way programs are displayed.
Sep 10, 2011 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Black lines across the top third of screen for 30 minutes till the TV warms up
Bad or leaking caps per an LG bulletin was issued for this model and all three series units of tis model. You'll need some test equipment, mainly a cap analyser 88, solder station and some expereince in SMD components to fix this unit. But it can be fixed, not an expensive fix, and if you're not too sure how to do it take it to a qualified tech... Let em know there is a bulletin on this unit...
Good Luck!
William Rayburn, CET
Premium Technologies
PS: If you need help finding a good tech try http://www.tvrepairpros.com/
Oct 05, 2009 | LG 37LC7D 37 in. LCD HDTV
POLAROID 37" TV - VOLUME STUCK ON LOUD - CAN'T TURN UP OR DOWN
sound like the volume is locked out you can access this in the main menu to unlock it
May 29, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Bush 37 inch model no idlcd37tv27hd
the tv is going in shutdown mode, is going to be power supply problem. check if your tv is under warranty because you will need a tv tech,
Dec 12, 2008 | Acer AL2671W 26 in. LCD Television
Phillips TV- Plasma Model #42PF7220A/37
A tech will need to come out. When the tech do come out have him unplug the Y main and see if the led goes solid greem if it does have them replace the Ymain and the Y upper/lower boards. Most likely that will be the problem.
Feb 29, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
15 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
