Question about Homelite Garden
What is the fuel mixture for a Homelite Textron model 10654 chain saw?
  • 323 Answers
SOURCE: The chain on my chain saw is slack.
The adjusting screw is usually found on the right side of the saw close to the bar, near the bottom. You will need to loosen the two nuts on the side that hold the bar tight. Loosen them until the bar lifts up and down (about 1/2") with your finger.
There should be a combination spark plug wrench and screwdriver that came with your saw. If not, use a slot screwdriverto tighten the chain while you hold the bar up with two fingers.
When adjusted properly, there should be no hanging slack in the chain when it is warm. It should rest just against the bar so that you can grasp it with gloves on and pull it toward you.
When it is tightened thusly, tighten the two side nuts while holding the bar up with two fingers. If you don't tighten the two nuts enough, it will loosen and the chain will have slack again shortly.
Remember that the hotter the chain gets, the looser it will be. Make sure your chains is getting plenty of bar oil. Never use regular motor oil.
Posted on Jun 08, 2009
  • 583 Answers
SOURCE: Homelite Textron chain saw UT 10403A ...need
25to 1 and .025 thou
Posted on Aug 06, 2009
SOURCE: what is the fuel mixture ratio for a homelite XL
50:1
Posted on Oct 17, 2009
dontbother10
  • 2220 Answers
SOURCE: I would like to know the fuel mixture for a
32:1 (1 gallon of premium fuel to 4 ounces of quality 2-cycle oil) according to this
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/a17d735d551f0f1e88256b78005f6a7b?OpenDocument
It will operate better on 50:1 (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil) once adjusted. HTH
Lou
Posted on Feb 21, 2010
SOURCE: HOMELITE Textron Chain Saw, wont stay running properly.
left my chain saw xl12 in the garage and the gas dried up need to rebuild the carb and clean up the gas where do I get a gasket kit so I can start for this unit
Posted on Feb 24, 2010
What is the replacement chain and bar for a homelite textron Little Red UT-10748
Ok, what you need to do is go on Google type in that model number UT etc etc and parts right after it. You will see a bunch of sites that have parts drawings, click on one of them, find your part numbers THEN do the same thing again, bqck to google, type in part number then the description, again you will see sites that will either offer the OM part or an aftermarket.
Nov 23, 2015 | Homelite Garden
CHAIN SAW HOMELITE FUEL
You should run your saw at 25:1
More tips and advice on different makes and model chainsaws here
Sep 15, 2012 | Homelite Garden
I have a Homelite-terry TEXTRON chain saw does it take a gas oil mixture?
I have a Homelite Terry Textron X76 T83-03010 Unit 50150.
how do you change the fuel line?
Sep 02, 2012 | Garden
Every chain saw uses as fuel a mixture of oil and gasoline. What is the correct mixture for a textron gasoline powered saw?
25:1 to 32:1
Start at 25:1. If it smokes too much or fouls a plug, go to 32:1 using a good grade 2-cycle oil.
Sep 27, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Chainsaw gas mixture ratio
An XL from that time frame recommends 32:1 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/d4b1071a456ca76c88256cd6001cc24c?OpenDocument
If my saw it would be adjusted for and operate on 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 27, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Can i get parts for homelite textron chainsaw 10045b
I saw no Textron listed. An inspection of your saw will probably reveal a "UT-", that seems to be the key.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches. Good luck
Lou
Jan 20, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite ut No. 10748 textron New sitting long
Is there bar oil in the tank? Oil pump and/or pickup tube in oil tank are usual suspects.
Jun 29, 2009 | Homelite ZR10926 16 Chain Saw
The preset is to turn them all the way in (Don't tighten them hard or you will damage the needle) and then back each out 1 1/2 turns. This will get you started. You can then run it at full throttle and turn the high speed jet in untill you hear a change in the RPM. Then turn it out untill you hear the same. Find the happy medium.
May 09, 2009 | Garden
Garden Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
