Question about Hardware & Accessories
Are there instruction for a timer model da-88-12w-1
This model is for outdoor lights
SOURCE: lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
Posted on Dec 14, 2008
  • 10865 Answers
SOURCE: need instruction sheet
Your unit has a lifetime warranty. Go to this website to get the instructions in PDF format:
http://www.hardwareinnovations.com/pdf/SA_210_IB61056_33.pdf GOODLUCK
SA 210 Zip Set Outdoor Digital Timer with 3 Outlets features a Zip-Set One-Step Set-up where you simply enter your area code and the timer is programmed. Your lights will automatically turn on at sunset, and auto-adjust for seasonal time changes. Other features include a random setting for added security, a 7-5-2 setting for full weeks, weekdays, or weekends. Battery back-up (batteries included) to save resetting time in the event of a power failure. It has 2 timed outlets, plus 1 extra untimed outlet for use with other products. It has an easy-to-read, large illuminated digital display, and 15 amp capacity. Lifetime warranty.
Product Description
Zip-Set™ Technology with One-Step™ Set-Up Two Timed Outlets + 1 Untimed Outlet Controls three Products Simultaneously Controls Outdoor Landscape, Security and Holiday Lighting, Pool/Spa Pumps and Engine Block Heaters Optional 4 On / 4 Off Settings Random Settings for Added Security 7-5-2 Feature allows you to set times based on the 7 Day full week, 5 Day work week, or 2 Day weekend Large Illuminated Easy-to-Read LCD Display & Keypad Battery Back-Up (battery included) saves resetting time in the event of a power failure Weatherproof 15 Amps Lifetime Warranty
Posted on Jan 23, 2009
VtToolMan
  • 704 Answers
SOURCE: intermatic outdoor can't reprogram. display reads NoOp
Les, First thing to do is to change the battery and see if the timer will allow you to reprogram it. Sometimes these timers will fail, as some models have a known history of failing fairly often.
NoOp, means non operating within the Intermatic line of electronic timers, so in order to see if the unit has failed or is just malfunctioning, due to a weak battery, remove the existing battery and install a fresh, new one.
You can remove the existing battery by flipping down the front switch panel and removing the battery tray with either your fingernail or a small flat bladed screwdriver. As your timer is showing the NoOp, you don't have to worry about losing your programmed on/off cycles, so you can take your time. Normally, if you're changing the battery, you get about 30 seconds to do this with some models of Intermatic timers, or you'll lose the settings. The newer models store the program regardless of how long it takes to change the battery.
Once you've replaced the battery, press the Reset button on the timer and allow it to refresh. If the NoOp is gone, just reprogram the timer with your on/off cycles and days and you're back in action. If the timer doesn't clear, you'll likely need to replace it, as it could be damaged and will not be able to be programmed again.
Usually, changing the battery and resetting the timer works about 60% of the time for me, as I've installed thousands of the various Intermatic timers in customer's homes over the years.
Hope you find this Very Helpful and best regards!
Posted on Sep 09, 2009
SOURCE: instructions manual
http://www.ccixpress.com/cci/Marketing/Woods_US_Timer_Instructions/TM_13660_InstrMan.pdf
Posted on Dec 02, 2009
SOURCE: need instructions for setting Globe
Use the on/off button to cycle through in the following order:
F = off
0 = on
1-9 = Number of hours unit stays on after detecting 15 seconds of low light
R = Random. After detecting low lux for 15 seconds, unit will select random number of hours to stay on. Will repeat randomization cycle in 24 hrs
d = On from dusk til dawn
1.-9. = (number followed by period) On now and will shut off after the indicated number of hours elapses.
Neat little timer. Have fun with it.
Posted on Dec 05, 2010
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
How do I set a Outdoor Timer Model 23ULD/3AOType 3R
Copy following link to identify timer, and see instruction manuals for each type:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Gene
h
Dec 08, 2013 | Woods Outdoor Lighting Timer
Westinghouse outdoor timer with 6 outlets instruction manual
1) Copy following link to help identify timer and download possible manual:
2) After viewing link above, add a comment with clear detail about timer
Dec 22, 2012 | Hardware & Accessories
How do I program my ge programmable timer model # 15193
Timer is unknown
1) Copy following link to identify timer, and read possible instructions for outdoor timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#outdoor
2) Copy following link for analog timers:
http://waterheatertimer.org/How-to-set-timers.html
3) If you have different timer, then view pages above for possible match, and/or add comment with clear description of timer.
Dec 21, 2012 | Hardware & Accessories
Stanley raintight outdoor 2 outlet timer instructions model # 28468
10-17-12
Copy following link, and scroll down page, to help identify same/similar timer and download outdoor timer manual:
Or add comment with clear description of timer, saying how it differs from timers shown on link above.
Oct 17, 2012 | Stanley Proto Stanley 31217 Digital...
Light are not working on my flood light I need to reset them, but i do not have the instruction.
1) You need instructions for Intermatic timer.
Specific instructions for T100 series timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
2) For additional information: Question posted under Intermatic T100 series outdoor timer, but model number is not given, and steps taken so far are not known.
Add a comment any time, and it sends email and I will respond with more detailed information.
3) Check that floodlights are not burned out, and that outdoor sockets are not dirty and cause bulb not to contact electric current.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
We need clear instructions for setting the timer
Woods makes several outdoor timers:
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
Need instructions for setting Globe outdoor timer photocell model one button on/off #16UL/PC-24222
F = off
0 = on
Nov 13, 2010 | Globe Electric Globe Indoor/Outdoor Lights...
How do you set a older outdoor noma light timer only 2 buttons
Hi.
See the instructions below in PDF format, instructions are for Noma two buttons heavy duty outdoor timer. Some model may be different in shape:
24-Hour Heavy Duty Outdoor Timer
Regards.
Ginko.
Jul 21, 2010 | Home
Hardware & Accessories Logo
167 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
