Question about ROOTS MAI TAI Ry2142BLK Watch
How to change time from military - ROOTS MAI TAI Ry2142BLK Watch
Can Fitbit Charge 2 time be changed to 24hour?
You can change to military / 24 hour clock in your profile settings at: https://www.fitbit.com/user/profile/edit
Dec 28, 2017 | Military Time Watches
How to Quit military time on Armitron IW-YP 12585A
Hi Bill.
Please allow me to try to help you.
Here is where you could find the answers to how to quit military time on Armitron IW-YP 12585A...
https://oureverydaylife.com/how-do-i-change-from-military-time-on-my-armitron-watch-12277699.html
http://office.manualsonline.com/support/armitron/clock/how-do-i-switch-from-military-time-to-normal-time--5401972
You could also find help in the form of the video that I have added here.
Hope that helps.
Best wishes. Regards.
Nov 06, 2017 | Armitron Watches
To be able to change to analog time from military time
Go to your events/calendar. Click the little settings symbol there. Then uncheck 24-hour time and save. How do I change my clock settings from military time to regular time.
just found this on the internet dont no if this will help you out if not let me no.
Nov 19, 2016 | Able Watches
How to change from military time to regular time
use the mode setting to change from 24 hr to 12hr
Nov 14, 2016 | Military Time Watches
My TGHK watch is stuck in ''military time'' and I've lost the instruction manual. Any ideas how to get it to am/pm mode?
advance the hours. The first time you go through the 24 hour cycle, it will be in am pm mode, the second time in 24 hour mode, the next time in am pm. Just keep advancing the hours until it comes up the correct time
Nov 03, 2009 | Watches
How do i get my athletic watch off of military time? It's a water resistant watch up to 165 ft. model # aw60447w
military time:
1. When setting the time on your watch, IF you watch can change to Military time(and most can)
2. when you are adjusting the hours go through a full 24 hour cycle. You'll notice that the 2nd time through it is on military time.. 3rd time through back to 12 hour day AM/PM cycle .. 4th time back to Military.
So you can do this as many times as it takes to get to the right time ..
In 24 hour time you will see an "H" displayed where you normally see and "A" for AM and "P" for pm.
Sep 23, 2009 | Watches
Time confusion
Possibly you can change it back by pushing the hour-setting button through a 24 hour cycle--you can see if you are on military time during the PM part of setting it. If it's on military, just keep pushing till you start over at 12 am again (hint: that's 0:00 in military.) At least, that's how it is on my watch.
Jul 15, 2008 | Timex 1440 Nylon watch
Set watch
I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
Feb 21, 2008 | Watches
ROOTS MAI TAI Ry2142BLK Watch Logo
Top ROOTS Watches Experts
Ansel Alberto
Ansel Alberto
Are you a ROOTS Watch Expert? Answer questions, earn points and help others
