Question about Pool & Spa
How do i rewire a hayward pump from 220 to 110
Where can I get a new start cap for a 1 hp Hayward super pump
Find out your model number on your pump by checking the hayward site, for the super pump the parts manual is http://www.hayward-pool.com/pdf/Parts%20Diagrams/Super-Pump.pdf
Once you figure out the part number for your super pump you can call a local pool and spa shop and they will order it, you can google the part number, buy it off amazon (personal choice), or call hayward at (908) 355-7995 (U.S.) to buy a replacement
Oct 05, 2013 | Hayward Pool & Spa
My Hayward pump was very noisy but now trips the breaker. I can turn the impeller from the rear pretty easily.
Hayward is synonymous with junk. Let me guess. It's been in service for about two or so years when the noise started. Eventually the motor will burn out. I've gone through two motors and a diffuser on my Hayward pump. It's already making noise again.
Jul 16, 2012 | Hayward Pool Products Hayward Power Flo LX...
I have a 1 hp hayward super pump. the model # of the motor is C48K2n143B1. I need to replace the motor only. is it a big deal?
If you've never done it before, it can be a bid deal. You will need to get the exact replacement motor (1hp square flange), a shaft seal, impeller wrench, and be prepared to replace o-rings and rewire the new motor. If you're not comfortable dealing with electrical/mechanical, you're better off getting a service tech to help you out.
Sep 15, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Instructions for putting Hayward Model EC-75 filter on pump for a inground pool
Here is a copy of the users manual for these pool filters. It should give you detailed instructions about installing the Hayward Perflex.
http://www.backyardcitypools.com/images/hayward/perflex-system-manual.pdf
Aug 30, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
I have a power-flo matrix pump from hayward. The Impeller will rotate manually, but the motor just hums and heats up . Is the motor burnt up and needs to be rewired? Can that be done?
Thank you for posting your question here on Fixya.com.
It is likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
As a rule it is not worth 'rewiring' these motors as the cost to replace them is so low.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Aug 28, 2010 | Hayward Pool & Spa
I need the instruccions manual for my Hayward pump model no. c4001575XES
This site that sells pool pumps has owners manuals for most Hayward pumps. If they don't have in on the website, they might be able to locate it for you. You might also want to try the Hayward website.
May 22, 2010 | Hayward Easy Clear 40 Sq Ft Cartridge Pool...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
