Question about Zyxel P660HW-D1 Router
Cant figure out to open nat
Cant figure out y i cant open my nat...not sure how either...i know i have to go to my router settings on the site for it and type in a password but not sure wat the password is
    Sergeant:
  • 199 Answers
The default is "1234" if you have changed it you will need to reset the router there shouuld be a small button on the router that you have to stick a pen or something small to reset it
Posted on Jun 23, 2009
I have an actiontec router and cant set my nat type to open. If i turn off nat i cant get on xbox live. It says in the actiontec website for my router that i have to do something with port forwarding to...
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is enabled
Aug 09, 2010 | Actiontec (GT701WG) Wireless Router
I have a Motorola WR850G i am looking to open my nat type for my ps3 system i also have a DSL Verizon cable modem which i have open the nat type for that now I'm trying to figure out how to open my nat...
If your using a router, you have to ENABLE the UPnp within your router settings. Once enabled your NAT should be OPEN.
If you do not know how to get into your router, you will need to ask someone you trust to do this.
Jul 30, 2010 | Computers & Internet
Change NAT to open
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Mar 14, 2010 | Arris SURFboard SBG900 Wireless Router...
My NAT setting is strict. ive tried everything i know to change it but cant. i have a silver motorola modem wit a black and blue linksys router but i cant figure out how to change the Nat setting. Im...
Microsoft has a support page to help you with your NAT settings. The prescribed solution is to "open" the following ports on your router:
  • UDP 88
  • UDP 3074
  • TCP 3074
1- Using your Browser, Log on to your router (by normally typing in the192.168.1.1 address check your router's manual to see what the defaultgateway address)
2- If you already know how to log in to your router, then skip thisstep. If you have never logged on to your router then more than likelyyou still have the default initial log in credentials (username: admin- Password:1234 ..... Again check your router's manual to be sure). Theminute you log in you need to change that password immediately, mostnetwork-savvy folks know that 90% of the people out there never resettheir router's initial password and they can log on and make anychanges to suit their needs, including locking you out of your ownrouter.
3- Once you are logged in click on sercruity, scroll tot he bottom and make sure "Filter Internet NAT Redirection" is set to "disabled" ,
4. now click on advanced routing
make sure
Nat is enabled.
5. now click on applications and gaming.
you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will edit theUpnp settings at the end.
6- You will need to find out what the static/dynamic (preferablyStatic) IP address you xbox360 has. To do so, go to the Dashboard, goto the Console settings page, and click on the network settings to seethe IP address (should be something like 192.168.1.x). You will needthat IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT PortForwarding table (From - To - IP address:)
8 - In the first line enter 88 under both "From" and To" fields, thenenter the IP address of the xbox in the field where you are to enter anIP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try theUpnp option. Click on your Upnp Advances settings enter the same information with the ip, and make sure UDP are enabled and checked for. use the port #s for your info as well in the chart. you can name them what ever u want under the application column.
  • UDP 88
  • UDP 3074
thend o the same for
TCP 3074
just make sure the tcp is checked and not udp.
if that doesnt work we can do a full reset on your router.
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, securitykeys, opened ports and services, etc., that you modified. (The defaultusername is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks.This takes about 10 seconds. (To avoid accidental resets, the smallbutton is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password.If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
please rate me, and mark this fixya if it has helped.
Nov 28, 2009 | Motorola Computers & Internet
I do not know how to change the NAT type to open on my computer
Can you check the Zyxel site for the latest firmware? Try NAT type 2 if an option.
Jul 09, 2009 | Zyxel P660HW-D1 Router
How to Open NAT?
Look for a setting like "Virtual DMZ Host". It's hard to tell for sure without knowing the make and model of your router.
Jan 14, 2008 | Dell TrueMobile 2300 Router (000001)
Zyxel P660HW-D1 Router Logo
185 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
