Question about Home
32L mineral water pot SMWP-32 - Home
Bunn automatic coffeemaker leaks water after making a pot
Tank and tank components should be delimed regularly
depending on local water conditions. Excessive mineral build-up
on stainless steel surfaces can initiate corrosive reactions resulting in serious leaks.
Feb 02, 2013 | Bunnomatic Corp. 10c Professional Brewer...
White stuff coming out of my iron
Spring water has minerals in it.If you want to be sure the water is pure,distilled water is best.(My city water is full of minerals,which means a cleaning with CLR is necessary quite often for my coffee pot and shower head).Distilled water was recommended for topping off car batteries back in the day before they were maintainence free.
Jun 02, 2012 | Rowenta Effective Iron
Sharp TV Model 32L-S400B - Reprogram Channels
Download the user manual to your Sharp TV by this link. It will ahve all details. OK?
May 21, 2012 | Sharp 32L-S400 32" TV
I have two and both are having problems! The first one - when I put a whole pot of water in only a half pot comes out. If I put another whole pot of water in on top of that still only a half pot comes...
  • The sprayhead may be clogged. Check the round disk (sprayhead) above the brew funnel. The holes in this part must always remain open. If they are clogged, remove the sprayhead and clear the holes using a toothpick. Always unplug the brewer before deliming or cleaning the sprayhead.
  • The brewer could be clogged with mineral deposits. See the Deliming Instructions in the Manual. NOTE: The frequency of deliming depends on the mineral content of your water.
May 16, 2011 | Bunn VPR Coffee Maker
Lost instruction manual. How do I clean coffee maker to get rid of strong acid taste coffee? MoldelB60 single cup coffee maker
Most coffee pots are cleaned by running 1 part white vinegar and 1 part water. Just put in the reservoir and run a cycle. Once completed, run again with 1/2 pot of water only and it will clean it. If you use your pot daily, this should be done once every few months. If you have foul tasting coffee, you should use bottled water to rectify that. Plain tap water has minerals that dilute the taste of the coffee and over time build a residue in your pot.
Oct 09, 2010 | Keurig B60 Coffee Maker
Coffee maker is not pumping water fast enough. takes over a minute to brew a 8 oz. cup. pumps water real slow.
have you tried cleaning it? Minerals from the water build up inside the tubing and make it run slow. Take a pot full of white vinegar and run it through a brew cycle. follow this by a couple of pots of cold water and you should be good to go.
Nov 04, 2009 | Keurig B60 Coffee Maker
The coffee comes out very slow and it seems like there is some sort of clog.
This may be caused by hard water mineral deposits.Run a cup of regular vinegar through a normal brew cycle followed by a full pot of water to rinse the vinegar from the machine. This will remove most mineral deposits.
Oct 06, 2009 | DeLonghi Coffee Makers & Espresso Machines
TV TURNS OFF BY ITSELF
Sounds like the Startup Relay is dropping out, you will need to replace it.
Mar 28, 2009 | Sharp 32L-S400 32" TV
Mineral/calcium buildup
I'm curious about the performance of the heater on this pot. Your output temp should be about 180 degrees F. Allow some of the water to run through the system and into a large mug. Measure the temp. If it is low, your problem may be the thermostat.
Apr 30, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Brew time
If you have hard water, minerals may have built up in the unit, slowing down the flow. You should be able to find some sort of mineral-dissolving treatment for it at your local grocery or hardware store. Make sure to run a few pots of plain water when you are done, to get any residue out!
Feb 21, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Home Logo
330 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
