Question about HP vs15 15"LCD Flat Panel Monitor
Video card motherboard hp vs15 - HP vs15 15"LCD Flat Panel Monitor
Im trying to connect my ps3 to hp vs15. i really need help!
HP VS15 model does not support HDMI cable input. (high definition multimedia interface) It only supports VGA (blue) analog signal only.
Hope it helps.
Oct 03, 2014 | HP vs15c Monitor
IBM 8303 DOESN'T SUPPORT MY FLATSCREEN HP VS15
2 steps:
1. plug the hp vs15 into another computer and see if it works, if not could be a bad monitor.
2. If you have the old monitor, plug it in to the IBM computer and in windows lower the resolution down to 640 X 480. Now turn off the computer and plug in the VS15 monitor. If resolution was an issue it should work now.
Hope this helps
Jan 31, 2012 | IBM Computers & Internet
My Monitor keeps going to sleep when i hook it up to my high end graphics card. My monitor is is a HP vs15
It may have gone into sleep because it does not detect the video signal from the PC or it has problem inside, you need to try it with another PC first and make sure to set the PC Video resolution not higher tahn the native resolution of this monitor: 1024 x 768 260Hz.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 22, 2010 | HP vs15 15"LCD Flat Panel Monitor
I want to connect my playstation 3 to my hp vs15. But after doing a little bit of research i am asked to change my display mode in order to get video from my playstation 3. hence my question is how do...
You change the video resolution at the video source, in this case, your PS3, not at the monitor. VS 15 has 1024 x 768 60Hz Maximum Resolution, so your PS3 cannot be higher.
You need to google 'how to change PS3 video resolution' If the PS3 resolution is set to high, the VS15 will display Out of range/format/video not support.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
May 20, 2010 | HP vs15 15"LCD Flat Panel Monitor
My HP vs15/vs17/vs19 LCD monitor just stopped coming on. No problems previously, no distortion, perfect and one day it went to sleep and never came back on. We rebooted, checked wiring, etc. Any...
Hello there kittensue.
Here's your geek-steer ...
Based on your trouble description, likeliest to be either the monitor OR the video card:
  • Connect the troubled monitor up to a "known good" PC system.
  • Swap a "known good" video card into the system hooked up to the troubled monitor, or vice-verse.
Deduction will reveal which is in need of repair/replacement.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 13, 2009 | HP vs15 15"LCD Flat Panel Monitor
HP w2408 ghost bands to the right of dark images on the monitor outside of open windows
Connect the lcd to another computer to verify the problem is the display. I have seen a bad video card cause this problem.
Jun 24, 2009 | HP vs15 15"LCD Flat Panel Monitor
Monitor going to sleep
Click start...control panel...power options...set monitor to never turn off.
Also, you may have a bad backlight bulb.
Oct 18, 2008 | HP vs15 15"LCD Flat Panel Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
