Question about Krups XP7230 Compact Super Automatic Espresso Machine
Krups xp7200 cake container lamp keeps burning
2 Suggested Answers
SOURCE: Krups Espresseria Automic XP7200 coffee machine
As this is an automatic espresso machine, I suspect that the cake container is where the "used" pucks of ground coffee drop into after your espresso is extracted. The container may not be fully seated in position. See if there is a door on the machine that the container may be hiding behind.
Good Luck.
-Steve
Posted on Sep 27, 2008
Krups ea 8050 error code 14
Not enough grounds going in to make the cake of coffee the correct height for brewing or the switch that detects the cake height is faulty.
Oct 21, 2014 | Coffee Makers & Espresso Machines
Krups xp7200 how to do descaling
Manual has procedure....read that section.
Jan 24, 2013 | Keurig B50 Coffee Maker
What should fridge temp be for cakes and cooked meats?
the ideal temp in a fridge is +5C,no colder,or your veg will spoil.
Nov 02, 2010 | Refrigerators
Where can I order a krups xp series seal MS-0A01503? It is a seal for the plunger that expels the coffee cake after brewing. It started to leak and I need to replace it.
Nelson Appliance has this: http://goo.gl/bsjqj. I think this is what you are looking for. The description they give is: Boiler center gasket / seal #MS-5015004 for use with Krups XP7000 series espresso machines.
Aug 31, 2010 | Krups Coffee Makers & Espresso Machines
My krups xp7200 is leaking water from the bottom. How can I open it to check the problem? thanks
You need to unscrew 4 screws in the front, three on the top (underneath the lid where you put the cleaning tablet), one inside the coffe container at the top, and pull gently, but firmly the little black nob inside the coffe container, that you use to adjust the coffee grinding, straight up. Then you can remove the coffee container on the top, and unscrew one screw underneath this container. Also, remove the two screws from the holes beneath the water container. NOW, you should be able to pull the front electronics off, and pull the main cover backwards, away from the front panel. You may have to bend it a little to get it completely off, but it is not a problem. Good luck! :)
Jun 15, 2010 | Microwave Ovens
Krups XP7200 series date problem
It seems that the dial knob and the electronic opto coupler don't work anu more. You can replace the digital panel by try to find a broken machine on ebay. Unless you are an electronics engineer like me (you can try to replace the optocoupler). See the post on leaking xp7240 for opening up the machine... it's tricky but easy.
Apr 14, 2010 | Krups XP7230 Compact Super Automatic...
How do I dismantle the grinder
I can remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. Take photos and remove the components from top till bottom to get to the bad parts that need replacement. Good luck!
Jul 21, 2009 | Krups XP7230 Compact Super Automatic...
Krups XP7200 wont grind beans (all lights flash)
See post on leaking xp7240. It is almost the same machine. This post explains how to fix it (valve is blocked but can be easily cleaned)
Mar 14, 2009 | Krups Small Appliances Espresso Machine
Good Luck.
-Steve
Sep 27, 2008 | Krups XP7230 Compact Super Automatic...
Krups XP7230 Compact Super Automatic Espresso Machine Logo
26 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
