Question about Hoover Whole House Bagless Upright Vacuum, UH71214
Hoover wholehouse blows air - Hoover Whole House Bagless Upright Vacuum, UH71214
Blows air out the filter area bag does not fill with air but nothing is clogged up
It sounds like your bag is not attached to where the air is blowing in. You will need to make sure this is attached nice and tight and everything is lined up.
Jun 29, 2016 | Hoover Vacuums
All of a sudden my hoover vacuum cleaner blows and does not **** I live in South Africa.All my other appliances work normally from the same plug
Take out the screws on the bottom and any on top
to expose all parts of vacuum
Look for a blockage of dirt and dust
Really need an air hose to blow out real good
Remove and clean ends and bearings on
rotating brush
Check for worn or broken belts
Jan 30, 2011 | Hoover Vacuums
Blows air out, not sucking in. Hoover Agility F215-900
It's most likely it's not blowing air out, rather the brush is kicking debris back and out due to loss of suction..
Another possibility with the power head is a cracked or leaky tube between the tank and power head.
For the tank, check all areas for clogs, and clear them.
Dec 19, 2010 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Al Terrain Spin Scrub motor running in reverse
if it dosent **** up the water send it back but some hoover steamvacs blow air to dry the carpet or floor faster
Aug 01, 2009 | Hoover F7431-900 SteamVac Vacuum
Rewiring a Henry Hoover
Ignoring for the moment the fascinating question of why you would actually want to do this...  I'm sorry to tell you it won't work. Swapping the wires over will make no difference.
Apr 20, 2009 | Numatic Henry Bagged Canister Vacuum
Husky 6 gallon dry/vac wont **** in air, only blows air out
Maybe you have the vac hose plugged into the blow out port.
Nov 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Blowing warm air
Is there a part missing on the front of the dirty water tank? On some of these machines, there is block that you take out so you can insert the hose in its place. So if this spot is open, then it can't suck and will be blowing warm air.
Dec 15, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Whole House Bagless Upright Vacuum, UH71214 Logo
24 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
