Question about Vehicle Parts & Accessories
Volvo electric windows stuck on up position, drivers side, how do I fix it?
Drivers side window stuck how do I fix it?
    Genius:
  • Vehicle Part... Master
  • 1,138 Answers
Probably the window regulator or motor probably less hassel to replace it than repair it remove door card there will be a few bolts to remove and take full unit out
Posted on Aug 17, 2014
1999mAZDA 626 drivers window stuck half way.any suggestions
If It Is Electric Turn Key On Hold Button In Up Position While Thumping In Inside Of Door Below And Slightly Forward Of Center Of Armrest-----This Is Not A Forever Fix--Brushes Bad In Window Motor-And Motor Has To Be Replaced. Once Up, DO NOT USE Until Replacement. Note: Use Rubber Hammer Or Side Of Fist--Using Other Things Will Damage Door Panel.
Feb 28, 2015 | Cars & Trucks
How do I re-initialize the drivers side electric window of my V70
Try disconnecting the battery for about 1 hr then try again. Some times they need to reboot to rest the stop points.
Sep 11, 2014 | Volvo V70 Cars & Trucks
1994 Volvo 940 T: the drivers side window will roll down but will not roll up how do I fix this?
you will have to remove the inside door panel and replace the motor that is attached to the widow braces this is an easy fix ,sometimes
its just stuck and needs cleaned out or taped on for good measure id replace it .its very small and not that hard to change really .
Sep 25, 2013 | Volvo Cars & Trucks
2001 Volvo V70 Drivers Side Power Windows
The Window that only rolls part way down, the stop for low position has moved apparently and must be manually reset. The other that won't move at all, your correct in checking the power to it. Pull the panels to access them.
Jul 14, 2017 | Volvo V70 Cars & Trucks
1998 Volvo V70 GLT - Drivers side electric window will not go up. it was partially lowered and then would not go up. Someone hit the lower switch and it went all of the way down. A. How can I get it...
Try pressing down till connects with window bracket, then try up & down. Good luck, Actuall sounds like you need to clenn the window motor plug-in's with some wd/40 next This is located in the driver side door pannel.good luck to ya. .
Mar 26, 2011 | 1998 Volvo V70
Drivers window stuck in down position
u need to replace the window motor
Jul 10, 2010 | 1995 Mercury Villager
Drivers electric window stuck in down position
actually you have thought of all but the prob. The track has jumped, making the motor not move the window. Sometimes you can gently slide the window up by hand and then the motor will catch the track and finish rolling the window up
Jul 04, 2009 | 1998 Ford Taurus
Vehicle Parts & Accessories Logo
50 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
