Question about HP Compaq nc6000 Notebook
What is multibay boot? - HP Compaq nc6000 Notebook
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
Why my hp compaq nc6000 laptop failing to boot from cd after selecting multbay
hi ,
go into your cmos or setup for the computer , find boot setup and change it to drive c:\ or hard drive 1 .........good luck Roy
Feb 18, 2012 | HP Compaq nc6000 Notebook
When a compaq armada m700 laptop is showing non-system disk or disk error replace and strike any key when ready
this usually happens when the computer is trying to boot from a disk that isn't a valid boot disk.
if you have a floppy drive plugged into the multibay and a floppy in the drive, try removing the floppy.
if there is no floppy involved, try to boot from your system recovery disks, as it's likely that the boot record on the hard drive will need repaired. your system recovery disks should walk you through the process.
Nov 03, 2011 | Compaq Armada M700 Notebook
On pressing power switch on the multibay light indicator is on and it does not boot.
Try unplugging the power. Disconnect the battery. Count to 10. Replace battery. Reconnect power. Turn on.
Mar 23, 2011 | HP Compaq nx5000 Notebook
Non-system disk or disk error replace and strike any key when ready.compaq 6220.I tried everything
This situation usually happens when your system Bios is set to boot first to a drive or media that doesn't exist. For example, the boot options in BIOS has your Multibay CD drive as first option and there is no disk or no bootable disk. So your computer tries to boot into it and doesn't find it. Anyway, the solution is to press F10 as soon as the notebook is turned on. That takes it to BIOS. Go to the last option on the right that says Advanced, select Boot Options, enable the Multiboot option and select the devices that you want to boot in order. For example, set your harddrive to boot first and multibay to boot second using the left and right arrow keys on your keyboard. Thats how it's on my Compaq EVo N610C starting with pressing F10 to go BIOS and thereafter. Even if the menus are different, Just look for those options. I did the same on my notebook and it works
Feb 12, 2011 | Compaq Evo N610C Notebook
Drivelock multibay password when i switch on a hp compaq nc8230
hi
please I have my Laptop hp compaq nc8230 who requiert drivelock. anytime when I swith on I waiting for longtime.I getting a message drivelock multibay password.I don't know that I do.thank
Jul 14, 2010 | HP Compaq 2510p Notebook PC
MultiBay drive will not allow me to copy on to CD
You may not have the correct discs,check type of discs it takes,ie CD-R,CD+R,CD-RW,CD+RW.
Jan 08, 2009 | HP Multibay (DG189A) DVD-RW Burner
BIOS upgrade?
u can use usb cddrive without update bios but unlike later versions of windows where you just plug it in and it detects it you will have to use an instalation disk for system to recognise device same with usb stick.
what mem do u have and consider xp (need at least 40meg to install)if u can fit 256 or higher ur laughing mem cheap as buttons these days.
Apr 01, 2008 | Compaq Armada M700 Notebook
Boot from dvd
your linux isnt set up to boot use widows inviorment
Dec 29, 2007 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
27 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
