Question about KitchenAid KERC507 Electric Kitchen Range
The slef cleaning alarm wil not shut off,door will not lock on oven
CMV9
  • 594 Answers
SOURCE: oven door lock
when in the cleaning mode the door lock will engage to make sure the heat does not get out. if it will not engage make sure there is nothing blocking the lock.
Posted on Aug 15, 2008
  • 6 Answers
SOURCE: oven shut down
Please call directly to KitchenAid/Whirpool and speak to the 'executive management team' - when I spoke to them they said this wasnt a common problem, they were not aware of the fault.. EVERYONE with this fault please call again.
Replacing the fuse each or not using the self clean function is not a fix!
Posted on Sep 04, 2008
wheelshot
  • 102 Answers
SOURCE: oven door locked
Your high limit thermal fuse has blown. Pull the range out and unplug it. Pull the back panel off and in the center of the oven you will find the thermal fuse. It will have 2 wires hooked to it on either side. This will be the problem child. If it is bad, it will show a broken circuit or no continuity. Replace this fuse if it reads bad (which it most likely will) and reinstall unit. Make sure to clean the vent in the front to insure that it is free from lint or insulation that would block or slow the airflow into the unit. This air keeps the unit from over heating during self clean.
Posted on Apr 06, 2009
  • 93 Answers
IT IS THERMOSTAT IN BACK PANEL ABOUT A 48.00 PIECETWO CLIP WIRES AND TWO SCREWS IT IS NOT IN TOP OF STOVE IT IS IN FLAT ACCESS PANEL BELOW
Posted on Jun 10, 2009
SOURCE: Oven door not locking for clean cycle
cool down
Posted on Nov 12, 2012
GE 1978 Slef Cleaning oven JKP26002wh 3 Layers of glass in door...How do I clean between the glass in the self cleaning aluminum window mechanism?
You will have to take the door apart to get to the glass that needs to be cleaned out. I would not recommend doing a self clean on an oven that is that old.
Dec 07, 2010 | GE JTP75CMCC Oven
We have a frigidaire fef354cjsa oven that has a self cleaning option. We started the self clean and it locked the door. 2 days later we cannot open the door still. The lock light is blinking. We have tried...
The best way to do is to pull the oven out if is built in and go through the top. If its free standing use a clothes hanger and make a hook and pull the latch to where youcan open the door. Your going to have to replace the lock motor assembly. Bit of advice though, slef clean is the worst invention ever and if you use it you will have more problems.
Nov 02, 2010 | Frigidaire Ovens
I pressed the self clean option and the oven locked but every two minutes an alarm sounds and the code F8 appears. The cancel option stops the alarm temporarily. How do I either clean the oven or cancel...
F8 code means your door latch assy needs to be replaced. Two options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch microswitch logic is messed up.
www.oc-repair.com
Feb 10, 2010 | Dacor ECD230 Epicure Electric Double Oven
Door wil not open after self-cleaning cycle.Code
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Sep 18, 2009 | Kitchen Ranges
Slef clean message E1 F5
You have one or two possibilities here, one is your control board is going out. The second is that the Latch to the door, or switch is failing causing the clean door message.
The cheapest fix would be to inspect the door latch and switch to make sure it is making solid contact.
A POSITIVE RATING WOULD BE HIGHLY APPRECIABLE.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | Whirlpool Kitchen Ranges
190d merc fob does not work operating with key disconnected battery alarm came on with hasards how do i fix
If you need to shut off the alarm without the fob insert your key in the drivers door lock and lock and unlock the car My 89 300TE does this on occasion this wil reset the alarm to off to rearm the alarm lock the car again
Jul 07, 2009 | 1991 Mercedes-Benz 190
Manual lever to lock self clean oven wil not lock
After sliding latch to its locking position did you press the self clean button on the control panel?
Mar 31, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Oven door locked i tried the self clean got scared by the smell
The door will remain locked until the unit cools, this is a safety feature.
Feb 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Slef cleaning oven Frigidaire electri clean oven lock will not un
set both start & stop timers to the same time.Turn on the selector and the temperature knobs to clean. Hold in the light button, on the right top side of oven, and hold for 15 seconds.
then turn off the selector knob. hold button again for 15 seconds and the lock should unlock,
then turn off the temperature knob.
Jan 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Beaumark oven self cleaning
I lost my manual for the appliance, i was wondering if anyone knows how to get one? Thanks in advance
Jan 07, 2008 | Whirlpool RF378 Electric Kitchen Range
KitchenAid KERC507 Electric Kitchen Range Logo
29 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
