Home | HP | Digital Projector Vp6120 Multimedia Pro... | I have a Hewlitt packard
HP Digital Projector Vp6120 Multimedia Projector
Problem for HP Digital Projector Vp6120 Multimedia Projector
By jordan_gundl on Jun 23, 2009
I have a Hewlitt packard vp6120. The projector turns on and goes into the main hp logo screen and counts down from 15 then the bulb stops projecting. On top of the projector the overheating LED is flashing as well as the power button. The manual says that if the overheating LED is flashing then it is a fan issue, but all fans are working. Could shed some light on what else it could be.
Solution #1
posted on Aug 30, 2009
Not Rated)
heller44
Rank: Apprentice
Rating: 0%, 0 votes
Look for any loose connectors on the top board, especially the white or yellow sense wires for each fan. I have just fixed this fault in one I have here.
No filters on these projectors.
Good luck.
Was this helpful?
Yes
No
Solution #2
posted on Jun 26, 2009
Not Rated)
mail214
Rank: Master
Rating: 90%, 11 votes
It's likely to be a Dirty filter. You may be able to clean it from the outside with a vacuum cleaner. If you can remove it, so much the better, as you may want to wash it out (gently) and/or vacuum (gently also, since it won't likely have the louvers on it that the housing does, and the media could get sucked out.) If that doesn't do it, let me know.
Was this helpful?
Yes
No
Popular Solutions for HP Digital Projector Vp6120
Questions and Unsolved Problems for HP Digital Projector Vp6120
Do you recommend HP Digital Projector Vp6120 Multimedia Projector?
Answer
Answer
hp vp6120 finds video but does not find laptop Have extended image onto hp but is not finding any... (More)
Answer
The red "wrench" is lit on top. The blue power light goes off. Is it the bulb?
Answer
seems i have the same problem with my hp vp6120 - lamp replaced (i have tried 3 spares so confident... (More)
Answer
i'm having a problem finding a replacement bulb for my HP vp6120. Philips lamp, type #UHP 250W,... (More)
Answer
hp 6120 cant seem to get rid of the red /blue or mauve colours.we have tried to adjust to either end... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Digital Projector Vp6120...:
Top Multimedia Projector Experts
Rank: Guru Guru
Solutions: 1178
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Multimedia Projector Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
