Question about RCA P52926 52" Rear Projection Television
Rca flatscreen tv the picture is lite color
Rca tv 52wh74 the screen isn't bright
  • 1030 Answers
SOURCE: My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Posted on Dec 21, 2007
  • 74 Answers
SOURCE: Older RCA Projection screen, Blue picture!
take the front speaker cover off, then remove the four screws on the cover behind it. you will see a 2"x2" black thing with 6 controls on it 3 on top three on bottom, your looking for "screen". they should also be marked r g and b, try turning the blue down (counterclockwise). it may help a little and prolong the life of your tv
Posted on Sep 10, 2008
Slinteriors
  • 8617 Answers
SOURCE: projection screen rca tv picture need to be relined
There a kit for that symptom on your model Leave an email at the following link stating your model number and what the symptoms are you can repair it for under 20.00 and they provide the oarts and instructions on how to do the repair. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Feb 02, 2009
  • 17 Answers
SOURCE: Our 1991 RCA projection TV P52150CP started being
One thing that you might check seeing that this set is so old, is the fluid in the tubes. Especially the blue one. The cooling fluid should look clear, if it looks cloudy that could be your problem. There are kits you can buy to change the fluid out.
Posted on Sep 01, 2009
Slinteriors
  • 8617 Answers
SOURCE: my 52" RCA HDTV Flat Screen TV
replace the deflection board. Your model uses the ITC222A deflection PSB-260 You can get the replacement deflection board from www.tvrepairworld.com
Posted on Apr 13, 2010
Why can i hardly see the picture on my rca 52wh74 its so dark
If you had the tv 4 long, it may need a new bulp.
meanwhile, I would clean the optics and such.
those tv`s usually have several fans inside and turn into
expensive air cleaners.
May 10, 2014 | RCA P52926 52" Rear Projection Television
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Aug 16, 2011 | RCA TruFlat 27F520T 27" TV
How to adjust monitor screen brightness?
hi. turn on the tv and then use the remote. click on the menu and scan thru til you find picture brightness or picture quality. J.
Jul 29, 2010 | Acer X223WB 22" WIDESCREEN LCD Monitor
I'm trying to improve the picture- seems to be TOO DARK- tv is 10 yr old ser3 935351541- ihave tried color adj etc
Rca Screen Control These sets have screen control adjustment usually located behind the speaker grill(pops off -velcro or press tabs) and convergence front board. There are 6 contols on a black molded assembly about 31/2"x21/2" square. adjust only the top controls marked "Screen R G B" the bottom ones are focus
Method:
-turn on set and let warm up for 30 min at least
-switch tv to blank unused video input channel
-adjust each control in turn until you see the picture glow (with the corresponding color) and slightly back off the control - repeat for each color - this will increase screen brightness and ballance your color
Hope this helped.
Oct 18, 2009 | RCA P52945 52" Rear Projection Television
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
Color on the picture is dark
You can adjust the brightness on the back of the set which says screen. put a mirror so you can see the screen and slowly turn the screw clockwise until you can see the picture.
Jul 10, 2008 | RCA F36650 36" TV
Rca projection tv the colors went all out of line how could i fix it
I need your model number because some rca's have STK convergence chips and others don't
May 05, 2008 | Televison & Video
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
Colors are distorted, brightness excessive
You may have a bad Fly Back transformer. The focus and screen(brightness) controls are located on this transformer. Some of the new RCA's have had problems with this transformer. If the screen control opens up the picture may either go dark or light which would cause your problem. Also a bad Picture tube could cause this. It shouldn't since the tv is not very old though. I've seen a few new ones go bad. Stargazer
Jan 29, 2007 | RCA 35V432T 35" TV
RCA P52926 52" Rear Projection Television Logo
15 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
