Question about Kodak ESP3.2 Inkjet Multifunction Printer/Copier/Scanner w/ Bonus
How do you clean the printer head on a kodak esp 3.2 printer
  • 295 Answers
SOURCE: Kodak ESP 3 printer does not print YELLOW
no,kodak replace printheads free of cost, and if they send a printhead and that doesnt solve issue and in next 30 days,u have same issue,then kodak sends a replacement printer. and esp-3 printers are considered o be in warranty tilll now even if they are 24 months old. kodak is the best.. ur issue will be resolved.dont worry
Posted on Jul 27, 2009
shockwave727
  • 262 Answers
SOURCE: how to clean print heads on kodak esp-3
Press and hold Cancel and Copy button simultaneously until the On/Off light flashes green. you will see a flashing green on your printer it means its now cleaning the printhead
You can also clean a printhead using computer., first you need to launch the Home center software On your computer and on the uppr right corner of the windows of the software click help icon(?) then go to maintenance and under maintenance you should see the clean printhead. GudlucK!
Posted on Nov 05, 2009
Testimonial: "Good advice, thanks - had already tried this tho'. I ended up phoning Kodak helpline and am having a new print head sent to me FOC."
SOURCE: How do I clean the print head for a kodak printer
This is for Kodak AiO printer that has home center software installed
1.On your computer, start the KODAK AiO Home Center software.
2.Click the Help (?) icon located at the upper-right corner of the Home Center window
3.From the Help toolbar, select Maintenance.
4.Click Printhead Cleaning, and wait for the printer to complete the cleaning.
If there is NO Kodak AiO home Center software installed
1. 5100 printer HOME CENTER should be use or open the printer access door wait for the printhead to move at the middle then close the printer access door forcing the printehead to eject ink on the printhead nozzle
2.5300 & 5500 printer press the MENU button > select CLEAN PRINTHEAD > then select BASIC/DEEP CLEAN
3. ESP3 printer [press and hold at the same time COPY and CANCEL button for atleast 10 sec or until the printer start moving]
Posted on Nov 21, 2009
  • 295 Answers
SOURCE: kodak esp 5 not printing properly and no yellow
Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
Posted on Jan 01, 2010
  • 103 Answers
SOURCE: psper jam in Kodak ESP all in one printer
try using the website www.kodak.com/go/itg
If still get the same paper jam error contact Kodak tech support.
Printer will be replaced if on the spot if bought from walmart for other stores you'll be asked to fax or email the proof of purchase.
Posted on Jan 26, 2010
On kodak esp 1.2 is there a head cleaning switch, as printer worked 3 weeks ago asked for ink, which has been done but now saying no ink
check your print head it is stopeed up, remove it and clean with water just the jets, or use qtips, plain water no chemicals, Matt
Jan 16, 2015 | Kodak Esp 1.2 All-In-One Printer
The black on my Kodak ESP-3 has stopped working
The black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Oct 21, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3250 printer only printing in blue and yellow
According to your problem first check your printer setup. You may have to change the black ink cartridge. But first clean the head of the printer and align the cartridges.
Jun 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak ESP 3 black doesn't work. I have ran
It sounds like you need a new printhead. The Kodak ESP 3 works in two stages, you have a printhead which is what transfers the ink to the paper then you have the ink cartridges. Change the printhead. You can try to clean it also, by removing all the inks. Taking the printhead out and soak it it warm water to dissolve the clog. Sometimes it will work.
Apr 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak ESP 3 all-in-one printer will not print
you may try to clean the printhead and recalibrate the printer. if this will not correct the problem, you need to replace the printhead. I suggest contacting Kodak technical support to have a replacement printhead.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do i clean printhead on esp 3 printer
Dear friend,
Please click control panel> select printer> properties> you will find option for head cleaning & test print. Thx
Jan 29, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP3:paper light flashes red,can't print-is totally useless
kodak has certain problems with esp-3 printers. it cannot give u a cash refund call kodak @ 1800 421 6699 . they will upgrade ur printer and give u a kodak esp-5. they have been giving esp-5 lately in return for esp-3
Jul 23, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to clean printhead
you did not specify the printer model but make sure you never ever clean the print head with any damp cloth or paper or anything coz if you do then you would end up damaging the print head............if it is a kodak printer except 5100 and ESP 3 then press the menu button on the printer and go to clean print head and in ESP series it is under maintenance and press ok on it and do a basic clean.......if it is 5100 or ESP 3 then open home center and click on the question mark on the top right of the home center and click on maintenance on the right hand side and there would be the option to clean the print head...........you can use the home center option with all the kodak printers but as there is not LCD on 5100 and ESP 3 so it is always done from the home center........let me know if this was helpful........
Jul 09, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have replaced the ink cartridges but the printer still thinks it is out of ink. Do I have to do some sort of reset? This is on the Kodak esp-3
Did you use a genuine Kodak cartridge or compatible? Some compatibles will work but give the empty cartridge message. HP is famous for this. Another thing you can do is make sure that the electrical contacts on the print head are clean on both the print head and where it contacts the printer.
Jun 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I need to change the printer head on my Kodak 5100 all in one printer
To install the printhead and ink cartridges in the: Additional search terms: print head, tank, replace
Jan 22, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP3.2 Inkjet Multifunction Printer/Copier/Scanner w/ Bonus Logo
15 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
