Question about Kenmore Elite HE5t Washer
HOW TO REMOVE CCU ON KENMORE H5T
NEED TO REPLACE CCU ON 11047789701 BUT CANNOT FIGURE OUT HOW TO REMOVE
3 Suggested Answers
SOURCE: need ccu board replacement
REPAIR CLINIC.COM ITEM#1164545 $179.70
Posted on Apr 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore front load FL35 code
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Kenmore elite he5t washer model 11047789701 flashing F01 fault code- does this mean ccu must be replaced?
Do not take this as definitive answer! I am not an expert. A F01 error is indicative that the Central Control Unit cannot get instructions from the EEPROM. If you have not already done so, unplug the washer for a full 2 minutes to clear any instructions in memory, then plug it back in. If you still have a F01 error I suspicion that it is a bad CCU board. You can try to run the diagnostic on page 8 of the service manual but I do not think it will run if it is a bad CCU board.
Mar 08, 2015 | Kenmore Elite HE5t Washer
No display only a ticking noise
You will need to replace the CCU on the unit. Here is the part to order.
To replace the CCU, just remove the top and you will see it.
Dec 09, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Wont start, error code f01
The F01 error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred. This type of failure generally requires replacing the Central Control Unit (CCU). You could try disconnecting the power cord for a couple of minutes and then reconnect the power cord. If it continues to flash "F01" I recommend calling a service technician to remove and replace the CCU.
Jan 16, 2011 | Dryers
Kenmore front load FL35 code
Jul 03, 2010 | Kenmore HE2 Plus Front Load Washer
I have a kenmore he2 plus washing machine that keeps giving a code of f-21 on the final rinse cycle. i cant seem to figure out why that happens. sometimes it works, sometimes not. what could be causing...
HI. This error occurs if the touchpad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding.
2. Unplug washer or disconnect power. Gain access to the touchpad/led and CCU assembly.
3. Check wire harness connections to the touchpad/LED assembly and Central Control Unit (CCU).
Replace failed component.(which will be the CCU, if the harness is connected without any faults or worn connections present)
Nov 25, 2009 | Kenmore Washing Machines
Is there a way to bypass the water level switch on Kenmore HE5t
No - it is vacuum operated. Just replace it.
Aug 10, 2009 | Kenmore Washing Machines
MY DUET AND ME
Ok, you have two issues here that will need to be corrected. check the details below.
F-11
Serial communication error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.(Most common issue here is a failed wiring harness)
F-14
EEPROM error
The Central Control Unit (CCU) receives it’s data from an EEPROM on board the CCU. If there is an error reading this data it will cause this error.
Potential Causes
• A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
• Check CCU.
Replace failed component.(if the reset doesn't clear thsi issue, replace the CCU)
Jul 22, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Our he3 washer just clicks when you hit the start button and the door doesn't lock after several clicks the screen flashes and the machine just beeps . Ive changed the door lock once and it's doing it...
its a bad contact at the ccu(main control board located at the top of the unit). just remove top panel by unscrewing the 3 screws in back of top panel. the ccu is located in back right in the center of unit. replace the ccu. what happens is the contacts from the ccu are welded inside, so they must of broken off by vibrations of time. replacing the door lock will not help. replace the ccu and you should be good to go.
Apr 06, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How to replace ccu on a kenmore he2 plus?
f01 code??? remove 3 screws on rear of top panel ccu is on right side toward frontrelaes tb will allow ccu to slide badck remove wire connectors by pulling small tb away from plug andpulling connector straight upnew ccu should wire up just like old one but try to chane one connector at a time to avoid confusion
May 21, 2008 | Kenmore Washing Machines
Kenmore Elite HE5t Washer Logo
69 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
