Question about Orbit Hardware & Accessories
I have an Orbit Model 62056 hose faucet timer that is leaking from the 2 small holes in the base of the unit?
Could the water pressure be too high?
  • 230 Answers
SOURCE: Danby PORTABLE Air Conditioner model
The base needs to be dumped regularly. The air conditioner sweats water during operation and the pan collects it. Your manual should give you the procedure on how this is done. In some cases there is a hose attached to the drain pan so that you can direct the drainage to a more conventional drain location.
Posted on Jun 27, 2008
  • 171 Answers
SOURCE: kitchen faucet , reduced water flow / pressure
Hi ssam1
I'm Harvey the Master Plumber.
You want to know if you can fix a sudden low volume /pressure delivery problem on an American Standard model AS4205100 H7, one hole / single lever with pullout spray And is it fixable by owner?
Yes and maybe!
All plumbing systems are plauged with debrie buildup. Every time you turn on a faucet the water starts moving and will bring bits of debrie up from the water main or well. Most are small and will pass through to be caught by the screen in the aireator. Sometimes a relatively large piece comes along and dosen't make it through to the screen. It is stuck in the body of the valve.
Fixing takes a little mechanical ability.
First, turn off the water to the faucet in question. Then carefully disasemble paying close attention to the order of disasembly so you can reverse the order when putting back together. As each part is removed inspect it for that troublesome bit. I find that a little bit of wire or a paper clip is helpfull. Carefully reasemble. If the volume is still low then you missed finding that bit. Try again or call in a local pro.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
  • 3600 Answers
SOURCE: Water in timer keeps running out the hole
the water valve has some deposits in it or the shut off valve is bad.
Posted on Jul 22, 2009
smokenic
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
  • 54 Answers
SOURCE: leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Posted on Sep 26, 2009
Evap air cooler
Thermostat too high, city water pressure too high (best pressure 50Lbs). Pressure regulator can hold the pressure down, replace it.
Nov 24, 2017 | Water Water Heaters
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Water hose Timer
Orbit Mechanical Hose Faucet Timer - Walmart.com
www.walmart.com/ip/Orbit...Hose-Faucet-Timer/16564903
Walmart Rating: 3.5 - β€Ž20 votes - β€Ž$9.36 - β€ŽIn stock
This mechanical faucet timer comes with inlet strainer screen and washer. It is very simple to use - just to twist the dial to the desired time (max 2 hours, or lock
Oct 12, 2015 | Washing Machines
I have two Orbit 62056 timers display not working, new fresh batteries installed.
After four years of service, the displays may have simply failed although failure of both at the same time seems a bit of a coincidence.
Feb 22, 2015 | Orbit 62056 1-Port, Single Dial Hose...
What is the 2nd connection on the side of the K2.5 for
Your pump will look similar to the attached picture:
Red circle shows the soap/detergent inlet/venturi.
Blue circle shows cold water inlet.
Purple circle shows your high pressure water outlet
Green circle shows safety valve, dumps water if the pressure inside the pump head is too great or or the water temp too high 7fccbf77-6a81-4a2d-a43d-3f88059f90be.jpg
Jun 24, 2014 | Karcher 2500 PSI Pressure Washer
High pressure due to back flow preventer
Add a variable regulator to the house side of the check valve. Also add a pressure tank between the regulator and the hot water heater.
Jan 04, 2013 | Watts Premier Watts LF7 U2-2 3/4 3/4-Inch...
Error code High Ref Pressure on a jandy AE 3000T-R
Make sure your water filters are clean and if you have an external by-pass, make sure it is not open. High Ref Pressure is normally caused when the refrigerant is not cooled off by the pool water circulating thru the heat exchanger. If your filter pump is not circulating enough water (normally around 40gpm) in the system then you will trip the high pressure sensor. If the HP sensor trips without the compressor engaging the try replacing the sensor.
Oct 26, 2012 | Jandy Pool & Spa
Hardware & Accessories Logo
158 people viewed this question
Top Orbit Hardware & Accessories Experts
Craig Butler
Craig Butler
Hippy_dd
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
