Question about Luxor 19822 COB
No colour on picture or dvd - Luxor 19822 COB
No colour picture while playing colour dvd
is there a setting on player to choose tv system? like pal or ntsc? i you try to play ntsc recorded dvd in pal system.it acts exactly how you describe here.
Nov 19, 2011 | Televison & Video
I have a tcl lcd monitor (l1905az) and I just connected a dvd player to it. I can see the picture and the volume is on but the colour is only black and white. How do I get colour
hi; check your lcd setting if its on ntsc or auto in picture option
if its on pal setting the picture will be balck and white ,
check also your dvd player output if ntsc.
those two has to be the same video system , if you use pal player set your tv to pal,
but most common dvd player is ntsc.
Sep 05, 2011 | Televison & Video
I am only getting black and white pictures when using the sony dvd -DVP-SR200D when hooked-up to tha TV
Change your tv colour System in to Auto mode.It will adjust in menu.Mostly DVD recorded on NTSC 3.58 colour system.After adjust on auto mode Colour will come.
Oct 30, 2010 | Sony DVP-SR200P DVD Player
We have reconnected our DVD to our new flatscreen and can see the picture, hear the sound but the picture is only black and white
This sounds like either the colour settings on the DVD are wrong for your new TV, or the TV has got the wrong setting for the socket that the DVD is connected to.
Go to the menu of the DVD first and look for picture settings etc. Or colour, keep your eyes peeled for the words PAL or NTSC.
Feb 06, 2010 | Toshiba SD-K770KU DVD Player
TV after removal of picturetube for playing music from DVDplayer
Why use the TV in hearing the sound from DVD
player. You can use some small speaker and connect it at the back of the DVD player.
Jan 07, 2010 | Televison & Video
Cant get color picture when playing DVD's
I too had the same problem. On the Vzio there are AV plug ins on the left side (not the back, but the left side). Use these jacks when connecting to the DVD player and choose the AV button on the TV remote. Viola!
May 27, 2009 | Sony Televison & Video
Yamaha dsp-a1
you need to set the ntsf or pal settings for hdtv and s-video is video1 video 2 or video 3 seting on input on remote
May 13, 2008 | Yamaha DSP-A1 Receiver
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Luxor 19822 COB Logo
15 people viewed this question
Top Luxor Televison & Video Experts
sureshd2008
gbob59
rugby prop
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
