Question about NAD C542 CD Player
How to repair
CD skipping
Repairing coby cx-cd118 cd player
hi there.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. ... If theCD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.31 Mar 2015
How to Fix a CD Player That Skips ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-a-cd-player-that-skips
Why does a CD player skip?They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.12 Aug 2005Buyer beware: to fix a CD that skips, first try good old soap and water ...www.telegraph.co.uk/.../Buyer-beware-to-fix-a-CD-that-skips-first-try-good-old-soap-an...Search for: Why does a CD player skip?
How do you fix a CD player that skips?Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lenscleaner.12 Jul 2010How to Troubleshoot a CD Player - YouTubehttps://www.youtube.com/watch?v=xAlPb7NBvz4Search for: How do you fix a CD player that skips?
or try this link for more help if you need it.
cd player skips Google Search
Nov 27, 2017 | Coby Lands Phones
CD player skips even though the same cd does not skip in other cd players
The laser in the cd player is most likely faulty or dirty. Buy a cd laser cleaner.
Aug 02, 2014 | Coby Cxcd248 Portable Cd/Cassette Player...
Cd player skips
CD disk bad. (audio disc bad or scratched)
or CD dont really support disk media format , is this a CDDA or MP3
some early MP3 disc drives do MP3 very poorly
or skips when you hit bumps in the road.
only that disc skips.?
Dec 23, 2013 | 2005 Toyota Sienna LE
CD player skipping
Make sure the unit is mounted level and not to secured that its pinching down on the unit
Jul 23, 2012 | GE 7-5295 Undercounter DC /Radio Combo -...
Kenwood portable cd player dpc-741 skips.
Hello
The skipping happens because the lens is weak,to solve this problem open the cd player so you can see the lens.Clean the lens with cotton wool dabbed in a little methylated spirit(wipe carefully).This should stop the skipping.
If the skipping continues then the lens is too weak to play CD's so it is best that you change the lens of your CD player.
Aug 11, 2010 | Kenwood Audio Players & Recorders
3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Mar 08, 2010 | Teac AD-600 3-Disc CD Changer
CD changer skips on bumps
There are two ways either the 90* or the 180*. If your having problems like skipping I'd suggest finding a place at the center of the car where there is less shock for the unit, like under your seat. I know changers have this 6 seconds or more memory so in case it skips, the first 6 sec ahead of the song is stored and play it to avoid the skip.
Oct 09, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Durabrand model cd-968 mp3 anti-skip cd player Does skip...
I understand what you are saying. The Durabrand is very cheaply made and the ani-skip actually does not work near as long as stated by company. I would buy more expensive player or a different brand.
Look for 60 Second Anti-Skip if you want a good one.
May 13, 2009 | Durabrand CD-968 Personal CD Player
My 02 Maxima's CD player freezes and skips.
my cd changer skips alot i dunno wht to do i cleaned it it woorks fine while sitting still but as soon as i drive it skips:(
Nov 21, 2007 | Car Audio & Video
Sony MHC-GX450 CD's Skip
Try using a laser lens cleaner. I have the Maxell Thunderon one thats on a Gold CD that you can get at best buy for like $20 or so, seems to work good here on the computer disc drives
Nov 17, 2007 | Sony MHC-GX450 CD Shelf System
NAD C542 CD Player Logo
114 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
