Question about Beverage-Air BM23
How do I better control temp in Beverage Air Kegerator?
I have a bm23 beverage air kegerator. At lowest setting it is too warm, I move it up a little, and it is below freezing. What needs to be done, I'm lost?
2 Suggested Answers
  • 1218 Answers
SOURCE: my BM23 beverage air kegerator runs constantly and
I would definately start there. That is what contols the cycling of the compressor.
Posted on Jan 30, 2011
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
How do I get the right temperature in a beverage air BM 23 Kegerator
either a problem with the thermostat or the probe for it has been dislodged and getting a false temp reading
May 18, 2014 | Beverage-Air BM23
I'm trying to find out the age of my Beverage Air BM23 Kegerator. It's serial number is #823620I.
Scott,
Your Beverage Air Kegerator model BM23 / serial: 823620I - that serial didn't bring anything up when I called the manufacturer but based on the first 2 digits of the serial and the roman numeral 1 at the end of it - it would appear that your unit was manufactured in 1982 (If that number was on a metal tag then it defiantly was 1982).
We specialize in cooler gaskets and can help you locate the gasket part your unit needs. We also are able to get many other hardware and accessory parts for Beverage Air units and other manufacturers. Let us know if we can help.
Matt at coolergaskets.com
orders@coolergaskets.com
855-288-2259
Aug 25, 2013 | Beverage-Air BM23
Beverage Air Kegerator Runs constantly gets too cold
yes sounds like a bad defrost terminator or timer?
not allowing it to go into defrost so compressor runs all the time and it frreezes up
Apr 29, 2013 | Beverage-Air Refrigerators
I have a beverage air kegerator that seems to work fine, but the evaporator fan runs constantly. Is it supposed to run constantly, or is it supposed to cycle on and off with the compressor, etc.?
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
Aug 13, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
I have a BM23 Beverage-Air kegerator. It was working great until a blackout last week. I had a surge protector on the unit, but ever since then, the temp. would stay around 48-50 degrees. I had an...
electrician do one thing, electricity. If the unit cools, the compressor is running. a power outage should not put the compressor in a "Weaken" state. I would check the starting components. don't overlook your surge protector causing a voltage drop. try running the unit without the protector.
let me know if I can be of any further help.
Mar 14, 2008 | Beverage-Air BEVBM23 Commercial Beverage...
Beverage-Air BM23 Logo
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
