Question about Sanyo Split System Air Conditioner
Water is leaking inside from the ac - Sanyo Split System Air Conditioner
My AC unit leaks water inside
Isidro, If it's a window unit you will need to tilt it up from the inside. Thank you and please leave me feedback. Clean around the bottom of any debris so it can drain on the outside.
Jul 12, 2016 | Panasonic Heating & Cooling
Leaking under neath heating unit but it's not the hose but a little white knob underneath unit
ac drain . There could be a blockage in the AC drain pipe that runs under the car. This can usually be unblocked with compressed air they jack up vehicle takes 30 seconds to fix with vehicle hoist.
When it blocks up the AC unit builds up with water and leaks clear water inside the car. if it was green water it would be the heater core leaking coolant.
Mar 20, 2016 | Cars & Trucks
2003 STS cadillac leaking water on both driver and passenger floor boards
It could be the sun roof. It also could be clogged drains from the sun roof. It may also be door seals Leaking. It could also be leaking around the bottom of the windshield. A good way to narrow it down is to get inside the car and have someone spray the outside of the car with a water hose. while you look for water leaking inside of the car. If it does it while the ac is on may be a clogged ac drain. however it usually just leaks on passenger side when it is that. well good luck.
Jan 13, 2015 | 2003 Cadillac Sts
WATER LEAKING INSIDE ON PASSENGER SIDE WHEN AC IS ON
The condensate drain hole or pipe must be blocked. This drains the water to outside the car.
Dec 13, 2012 | 2005 Hyundai Tucson
Water from ac leaking inside on floor, drain tube open
Pull the fan and blower out of the enclosure and make sure the drain is really open, i will bet it isn't and has leaves blocking it on the inside.
Sep 07, 2012 | Dodge Cars & Trucks
What are things that could be wrong if the car is not holding water and its leaking on the inside of the car and the heater core is already disconnected
The only other location water forms inside the car is the AC condenser. If the drain tube for that is blocked and your running the AC water will leak on the passenger side front of the carpet.
Jul 02, 2011 | 2002 Chevrolet Malibu
AC works fine but water drips on passenger side
this is normal, water is the condensation leaking out,but if leaking inside the van then the drain is pluged up, the drain is on the pass/side outside the van on the firewall,blow air into drain or stick a coat hanger in to hole until water leaks out,
May 14, 2010 | 2001 Chrysler Town & Country
The water that drains from the airconditioner to outsied is clogged up and not draining how can i unclogg it myself?
I can tell you a few stories of my own - I've had this problem myself and water will eventually build up and leak inside your house - you don't want it to leak on your electrical outlet ! I do not know how long you had this unit or how old is it, but these things can happen over time due to dirt, dust or other foreign objects or rust. Some AC units have fan spinning and picking up the water and spraying it on evaporators, most of it should be evaporated - only excess humidity will cause dripping - on older models water should drip outside through an opening or two at the back of the AC unit.
Make sure your AC is not level, and is tilted about 20 degrees outside, allowing the water to flow outside the AC unit.
You will need to find a way to access your AC unit from outside, locate the areas where the water drips normally, you should see openings, using an object (paper clip, pipe cleaner, etc.) try to insert it in the holes back and forth until you dislodge whatever is blocking the hole - be careful not to damage the very deliate fins at the back of your AC.
if still no water drips then take a ladder and climb up and you shuold be able to see from the inside there should be a slope or container where water accumulates before dripping out, is there ANY water there ? If you mostly see water farther away then your AC is probably not tilted enough to allow water to flow out.
If there is neither any water towards the outer edge where it drips, nor inside, farther away nor dripping inside your home, then it is probably being all evaporated or your humidity level is under control. The more your air has moisture the more water will be produced inside your AC, any excess moisture will accumulate inside your AC - if your AC manages to evaporate all of it, and no leaks inside, good for you, I wouldn't touch it.
Another tip - when you shut down your AC, do you hear swishing and unusual sounds of water ? that could mean accumulated water not being evacuated - Although it IS normal for some stagnant water to remain in your AC - do not worry about that, as long as it doesn't leak inside.
Sep 01, 2009 | Heating & Cooling
Water leak on passenger side on 99 chevy s 10 not anterfreeze, leaks when not being driven
there is only one thing that leaks water there, that is the AC condensation drain, water forms as part of the AC cooling the evaporator core, this water must be drained away or it will flood onto passenger area, so there is a drain on the passenger side at bottom of firewall, will leak allot of water depending on how humid the air is.
May 05, 2009 | 1999 Chevrolet S-10 Pickup
Sanyo  Split System Air Conditioner Logo
44 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
