Question about Earthquake 8 in. Earth Auger Bit
Need carburetor & governor linkage dia. for Tecumseh Lev 120 361569C
Our snow blower with a Tecumseh model OHSK120 snow king engine starts but runs full throttle!! Any ideas?
Stuck or bent governor, governor linkage or throttle. Try moving the throttle and see if all the linkages move with it.
Jan 25, 2017 | Tecumseh Garden
I installed a 632690 carburetor on my older sears 10 hp riding mower. The mower starts but I can't adjust the speed. I need a diagram on how to connect the linkage
interesting
Tecumseh 632690 - Carburetor
if still original
the sear should have a Tecumseh 11 hp motor
the pictures are the original governor and carby set ups for a sears 10 hp
Oct 18, 2016 | Sears Garden
Honda Gv 100 works well if grass is short to medium loosing power with high grass any idea
Patrick, Ensure mower has good gas, good spark plug,Is the blade good and sharp. Clean any dirt, grass etc, form around the carburetor and governor linkages. It is possible the governor on engine may need adjusted, or spring off or a dirty carburetor needing cleaned internally. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Governor Adjustment and How They Work Honda Briggs Tecumseh Kohler etc
How Small Engine Governors Work any governor setup
honda governor adjustment Google Search
Apr 07, 2016 | Honda Garden
Governor linkage need to see cannot get it set
Check out CHAPTER 4 GOVERNORS AND LINKAGE it shows the different governor systems used on Tecumseh engines.
http://www.barrettsmallengine.com/manual/tecumsehlheadmanual.pdf
Feb 06, 2016 | Tecumseh Snowblower Snow Blower Starter...
How do correct RPM surge on a LH 195 Tecumseh engine
Hi you're governor gears inside the motor could b the problem ...good luck
Aug 11, 2015 | Tecumseh Garden
My Tecumseh snow blower engine races when running and sounds like its going to blow up what could this be
It sounds like your governor may be the problem. Check to make sure that the linkage from the carburetor to the governor is connected and not impeded in any way. If it is not a linkage issue, then I would suspect that there is a different problem with the governor. You may have to bring it to a repair shop if this is the case.
Good luck with it.
Feb 13, 2015 | Garden
Sears Craftsman mower-Tecumseh engine 3.75 HP- wouldn't start-replaced air filter & spark plug; dismantled carburetor and cleaned it; now it will start but only runs for a couple of seconds and dies....
check the linkage for the governor, maybe on the wrong side,when off it should be pushing the throttle wide open, the governor brings it down after start up!
Jul 06, 2010 | Craftsman Garden
Earthquake 8 in. Earth Auger Bit Logo
457 people viewed this question
Top Earthquake Garden Experts
cwradio73
Robert Hunt
Are you an Earthquake Garden Expert? Answer questions, earn points and help others
