Question about GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and freezer do not get cold but unit has power
Unit just stopped cooling but all lights, etc are on
  • info93111 Jun 23, 2009
    Thanks. the condenser coil was dirty so I cleaned it. The compressor is hot, so I will leave it unplugged overnight and try it again in the morning. Thanks for your help!
    Scholar:
  • 91 Answers
Check the freezer fan to ensure it is operating. If it is and there is at least air movement, maybe cool, but not cold, first thing to check is the condenser coil located either at the rear bottom or front bottom. Make sure it is clean. Dust/dirt can clog the condenser preventing the unit from rejecting the heat. Same as with your central a/c. If the condenser gets dirty/plugged, your a/c will stop cooling. Other possiblity is the compressor is not operating. You should be able to hear it operating, will sound like a low hum with slight vibration. In the event the compressor is not operating, unplug the refrigerator, gently place your hand on the compressor, (it will be found in the rear bottom) to determine if it is warm, hot, etc. If it is hot, leave the refrigerator unplugged for 10-12 hours to cool. There is a thermal overload within the compressor to shut it down in the event of overheating. While the refrigerator is unplugged to cool, make sure the condenser is clean. Most causes of compressor overheating are related to a plugged/dirty condenser. Let me know if this helps.
Richard
Posted on Jun 23, 2009
3 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: freezer and fridge not cold, but unit has power
If your model is the PSS26MRSS and not cooling we need to unplug and examine the control board on the back of refrigerator. It is located behind a panel cover on back with sheet metal screws holding the cover in place. Check both sides for burn marks or signs of heat or loose solder connections..Sea Breeze
SOURCE: freezer & refrig not cold
change the filter. to do this recover the freon(gas), remove the filter , replace it by new one; do the vacuum and then charge again. Work must be done by a certified technician. do that at your own risk
Posted on Aug 30, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer and fridge not cold, but unit has power
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Nov 12, 2008 | Refrigerators
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
375 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
