Question about Sewing Machines
Fix timing on jukiDDL227 - Sewing Machines
Brother XL 260I hook timing. My needle doesn't catch the bottom thread. How do I adjust the timing to fix this?
Make sure you are using a brand new needle. Old, damaged or bent needles often will not pick up the bobbin thread.
Search the internet for "sewing machine timing"
There are multiple web sites and videos that discuss fixing timing issues.
Oct 01, 2016 | Brother Sewing Machines
How to fix timing on Kenmore 70 sewing machine
Try talking to the people at the link I attached. There are about 7 different adjustments to fix timing issues. Good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Feb 04, 2015 | Kenmore Sewing Machines
Fix timeing
DO YOU UNDERSTAND TIMING TO BEGIN WITH? ALSO, DO YOU KNOW WHAT A HOOK IS AND WHAT IT DOES? IF YOU KNOW HOW THEY FIT TOGETHER ALONG WITH THE NEEDLE THEN YOU WILL UNDERSTAND HOW TO FIX YOUR TIMING. PLEASE CHECK THIS OUT AND YOU'LL BE READY TO FIX THE TIMING.
Nov 07, 2014 | Sewing Machines
Singer hook timing - needle breaking
Not an easy fix. This one is going to require someone to timing knowledge to fix. Generally, there is a plastic gear with 2 screws that needs to be release in order to reset the timing.
Aug 10, 2014 | Singer Confidence 7463 Computerized Sewing...
Juki dln 415-- timing fix Needle broke, #10 sewing
i have the exact problem with my juki dln-415..any help would be appreciated..
Aug 17, 2013 | Sewing Machines
Broke a needle and now the bobbin thread won't pick up
This is something that is very delicate and requires experience to fix. It is a timing issue and sorry to say you are going to have to take it to a sewing machine shop to get it fixed. in most cases this is a small charge around 50-80 dollars to fix.
it would be way to complex and long to put everything here to fix it yourself.
Dec 28, 2008 | White Sewing White 3032
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
