Question about Dri-Eaz Products Dri-Eaz CMC100 Compact Dehumidifier
Drieaz CMC 100 E2 code
What is the E2 code!
My Danby dehumidfier model DDR2510E showed the code E2 after I emptied it and now won't work and no where in my manual does it say what to do or what it means.
Hi There,
The E2 error you are receiving is likely the float switch sensor when turns the system off when the bucket is full. Please contact our customer service department to be connected with a service depot in your area.
1-800-263-2629 Business hours are Monday to Friday 9am-4pm
Thank you!
Jul 28, 2012 | Danby Dehumidifiers
E2 error
Unfortunately, for whatever reason, Haier does not list the Error Codes and what the problem is, in their Owner's Manuals. To find out what E2 indicates you will have to contact Haier Customer Support
1-877-337-3639. It's very important to have your Model Number handy before you call.
Hope this helps you to get the answer. Thanks for choosing FixYa.
Aug 24, 2011 | Haier 45-Pint Dehumidifier
My dehumidifier is showing an E2 code on it. It is a brand new haier, can you help me out with this problem?
E2 Code indicates a Sensor Error automatic shutdown. To find out which sensor it is you will have to call Haier Customer Support 1-877-337-363.
In the meantime, turn the unit OFF & unplug it for 15 minutes. Then plug the unit back in and turn ON. ON. Hopefully the unit reset itself and reverted back to the original factory settings. And you can set te humidity extraction level where you desire. If the error code reappears, definitely contact Haier, as youtr unit is still under warranty.
Jul 18, 2011 | Haier 45-Pint Dehumidifier
What does code E2 mean
E2 Indicates that the filter needs to be removed and cleaned. It's a good idea to clean the filter at least once every 2 weeks, as standard routine maintenance. Be sure to turn the Master ON/OFF Switch to OFF and unplug the unit, before removing and cleaning the filter. You can access the filter by pulling on the filter frame handle on the right side of the unit, behind the front louvers. You can either vacuum the filter or wash it in warm soapy water (dish washing detergent), rinse it and dry it thoroughly, before reinstalling it. A hand held hair dryer will dry it pretty fast.
Hope this helped you to solve the problem.
Jun 11, 2011 | Haier 45-Pint Dehumidifier
I have a new DE45EK unit that has an error code E2. I powered it down for one hour and the code does not clear. First what is this code as it isn't listed in the guide that came with the product. ...
After turning the Master ON/OFF Switch to OFF, unplug the unit for the wall outlet and wait 12 -15 minutes. Then plug the unit back in to the wall outlet and turn the Master ON/OFF Switch to ON. That 12 - 15 minute timeout, should have allowed the unit to reset it self and clear that unknown code.
Since you are not having success using Haier's Customer Support Number, here's their email address
productinfo@haieramerica.com <productinfo@haieramerica.com>
Hope this helped you solve the problem.
May 16, 2011 | Haier DE65EJ Dehumidifier
Haier 45 Pint Electronic Dehmidifier Error Code E2
Jason, currently the only 45 pint dehumidifier that Haier sell is Model # DE45EK or DE45EK-L or EK-T. If any of those matches the Model Number of yours, you can down load and print the Owners Manual from the link below. However, the model numbers I listed make no reference to Error Code E2. If your Model Number does not correspond to any of those numbers, your unit is probably no longer manufactured or available.
http://www.haieramerica.com/en/asset/product/4ba7175e54
With that said, there are two things you can do. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then, plug the unit back in and turn the Master On/Off Switch to ON. Did the Error Code clear itself. If so, set the controls as you normally would.
If that didn't solve the problem you can contact Haier Customer Service at 877-337-3639 and they will advise you what to do, to clear the error code.
Apr 15, 2011 | Haier Dehumidifiers
Haier dehumidifier model de45ej-t What does code e2 mean? Unit does not run.
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
Jan 09, 2011 | Haier DE45EAL Dehumidifier
My Duracraft DD-TEC10E dehumidifier has come up with an E2 message that I cannot clear to make it work, any ideas?
DIY fix for Duracraft TEC10E E2 error, in case it's useful for others:
(When I tried to get a replacement temperature sensor via UK/Ireland support (kaz.com -> www.hot-europe.com) I was told that a replacement sensor was not available, nor was my unit serviceable).
Anyway, after a bit of messing with a variable resistor, I found that it would trigger E2 at a resistance of 560-580K, and also at resistance < ~1K (I stupidly destroyed the faulty temperature sensor trying to take it apart, without first checking what kind of resistance it presented, so I don't know whether mine broke OC or shorted).
Assuming an NTC thermistor, and a threshold of 0degC - the sensor is just to stop the dehumidifier cooling coil from icing up AFAIK - a 150K NTC thermistor with 'B'(25/100) value of 4400 should give a suitable replacement, with a 0degC resistance of 579K.
I wasn't able to find an exact such replacement, but I got a 150K/B~4000 from Maplin, put a 170K resistor in series, sheathed it up and installed it, and initial results look good - putting an ice-cube on the new sensor will trigger an E2 on the unit.
YMMV.
Nov 29, 2010 | Dehumidifiers
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Jun 30, 2010 | Haier HD451E Dehumidifier
Dri-Eaz Products Dri-Eaz CMC100 Compact Dehumidifier Logo
60 people viewed this question
Top Dri-Eaz Products Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dri-Eaz Products Dehumidifier Expert? Answer questions, earn points and help others
