Question about Vehicle Parts & Accessories
What are the torque ratings for brake bolts on a Dodge Journey?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Just tight. don't strip them. if it doesn't tighten down its already stripped or you might have grease on them. wash it off of them if you do. they will come loose if they have grease on them.
Posted on Sep 09, 2014
Will the bolt pattern of a ford escape match the bolt pattern of a dodge journey?
What bolts are you talking about ? More specific detail information would help.
Nov 12, 2016 | Ford Cars & Trucks
What is the hub nut torque spec for 2011 Dodge Journey?
are you talking about the big 32mm nut that holds the CV axle to the hub?
2012 Wheel Bearing Front Brake Chassis Suspension
as seen on diagram as #1?
it's stated in that forum as 118 ft lbs & great tip at step #6 to get it to the correct torque setting
Mar 31, 2015 | 2011 Dodge Journey
What is the torque specs for 2005 durango slt 4x4 ball joints upper lower and brake bolts
60 foot pounds for the ball joints and 30 foot pounds for the brakes. This is nominal. I use a impact gun on thee. No torque specs. Brake bolts, just take it easy on them.
Feb 28, 2015 | 2005 Dodge Durango SLT
How do you replace the front brake pads on a 2010 Dodge journey?
remove the wheel after supporting the car,with a jack stand, then you remove the two bolts that holds the brake caliper then remove the old pads then you push back the caliper piston with a clamp or a big channel lock pliers replace the new pads and after you did the two front wheels start your car and before moving pump up the brakes properly
May 03, 2014 | 2009 Dodge Journey
How to replace front disc brake pads on a 2009 Dodge Journey?
remove the front wheel and support the van then remove the two bolts that hold the caliper then remove the old pads then using a clamp or big channel lock plies press the caliper piston in so the caliper can go on after you put on the new pads after you would of replace your wheels pump up your breaks and check to see if you need to put in some more brake fluid
I need torque specs for the head bolts on a 2004 Dodge Stratus Coupe 2.4L SOHC
For 2004 Dodge Stratus 2.4L SFI SOHC 4cyl the Head Bolt Torque sequence
------------ | 10 6 2 3 7 | | 9 5 1 4 8 | ------------
Step: 1 - Torque to 25 ft/lbs
Steps: 2 - Torque to 50 ft/lbs
Steps: 3 - Torque to 50 ft/lbs
Steps: 4 - Turn 90 degreesRecheck final torque in sequence
Caution:Engine uses torque to yield head bolts (TTY) that permanently stretch during initial installation. New head bolts must be used when cylinder headis replaced or re installed to obtain proper torque specification.
Hope helps (remember comment and rated this).
Aug 02, 2010 | 2004 Dodge Stratus
What is the sequence for the bolts on oil pan, for 2000 dodge grand caravan? What is the torque for bolts for oil pan for 2000 dodge grand caravan?
For the 2.8L there is no sequence. Torque for the bolts are 105 in.lbs.
For the 3.0L torque is 50 in.lbs. in sequence:
For the 3.3L and the 3.8L, no sequence but torque each bolt to 105 in.lbs.
Please don't forget to rate!
Jul 12, 2009 | 2005 Dodge Caravan
Need bolt torque and order for 1988 dodge heads
Torque for your bolts are 105 ft.lbs.
looking forward it would look like this for the order
7 3 1 5
8 4 2 6
Hope this helps you!!!!!
Don't forget to rate!
Mar 17, 2009 | 1988 Dodge Dakota
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
