Question about Lenovo ThinkPad R61 Notebook
Lenovo r61 four beeps - Lenovo ThinkPad R61 Notebook
no_pc-gst
  • 58 Answers
SOURCE: lenovo r61
Please look here:
http://www-307.ibm.com/pc/support/site.wss/MIGR-67856.html#bluetooth
Drivers and software - ThinkPad R61
Communications: Bluetooth
Communications:
Bluetooth
R61
Bluetooth Enhanced Data Rate software
Windows Vista
03 Apr 2008
v6.1.0.4500
Windows XP, 2000 25 Aug 2008
v5.5.0.4300
Microsoft Bluetooth support
Windows XP 21 Sep 2005
v2.00
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70450http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70450
Posted on Dec 30, 2008
abhi_patil
  • 569 Answers
SOURCE: i have lenovo R61 T7100 every time i insert a
which is the operating system you are using
Posted on Jun 09, 2009
bhagyavichar
  • 414 Answers
SOURCE: Lenovo R61 beeps four times and according to
assuming that u r a professional, the bios is not flashed in a wrong way n the ram(s) r ok..
check cmos battery & i/o cables/connectors r properly inserted..clean the teeth of ram(s) using a rubber to remove carbon coating n isopropyl alcohol, n resit it..
..well itz always better to hv a supervision of service center as they r sparsely available at the local market, we usually donot replace the system board as whole but try to repair using scraps n spares..
however, probably system board can ordered online: http://www.thinkpadmedic.com/listing.asp?PL=ThinkPad&CL=SB
Posted on Oct 27, 2009
SOURCE: Lenovo ThinkPad R61 Fan
Were you able to fix it? I took out the fan and cleaned it with a toothbrush (didn't disassemble it). If it worked, can you provide some insight into what you did?
Posted on Mar 12, 2010
Geekman
  • 32281 Answers
SOURCE: i hv lenovo thinkpad r61.. i hv drivers bt,itss nt
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows XP or Vista devicedrivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true You can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
Posted on Dec 02, 2010
How to reset lenovo thinkpad r61?
Please follow the steps below to reset the lenovo to factory settings
Note: All your data will be lost. So keep that in mind.
So take the backup of your data first in a separate HDD or flash drive.
1. Switch off the Computer
2. Press the power button and then immediately start tapping f11 key on the top of your keyboard.
3. You will hear a beep sound and then stop pressing it.
4. You will get the screen says windows is loading files. Wait untill it finishes.
5. Select the default language which is US and Click on next .
6. Enter your login credentials (username and password) if you use to login to the windows.
7. Then you will get the system Recovery Options screen where you need to select the last option "Lenovo Product Recovery"
8. Again preferred language will be English US and hit Next.
9. Accept the terms and conditions and hit next and then hit Yes on the warning.
10. Then it will start resetting the Lenovo Think pad to the factory default with no previous data. Same as when you purchased it.
If you have any query you can ask before restoring the Computer.
Hope this helps you. Reply if that fixes your issue.
Sukhiii
May 07, 2014 | Lenovo ThinkPad R61 Notebook
Lenovo r61 startup repair is not working
What were you doing before it happened?
Apr 15, 2014 | Lenovo ThinkPad R61 Notebook
Lenovo r61 screen
Open the panel on the back and remove the ram. Boot the computer. If the boot code changes then it's probably bad ram. If it's the samew beep code then probably a bad motherboard
Jan 20, 2014 | Lenovo Computers & Internet
I am hearing 4 beeps 4 times during power on, but system does not start- IBM thinkpad lenovo R 61
Usually this means that the memory is defective or has been removed or popped loose in its sockets. Try to reseat the memory DIMMs or replace them.
Sep 24, 2013 | Lenovo ThinkPad R61 Notebook
Remove dent
IBM/Lenovo ThinkPad R61 Notebook PC >
Bottom Case Cover, (Base Enclosure),
http://www.ebay.com/itm/NEW-IBM-45N4073-Lenovo-Thinkpad-R61-15-4-Bottom-Case-Base-Cover-42W2231-/360642073440?pt=US_Laptop_Housings_Touchpads&hash=item53f7f15360
Keyboard/Palm Rest Cover Bezel,
http://www.ebay.com/itm/IBM-ThinkPad-T61-T61P-R61-14-1-upper-keyboard-palmrest-bezel-cover-42W2466-/400491727269?pt=LH_DefaultDomain_0&hash=item5d3f2ac9a5
Palm Rest Cover,
http://www.ebay.com/itm/Palmrest-Assembly-Cover-IBM-Lenovo-ThinkPad-R61-R61i-14-1-Laptop-/281030800308
Not advertising for seller nor website. Just examples.
Here is the free HMM from Lenovo Support.
It is the Hardware Maintenance Manual. The Service Manual.
Shows and details how to replace the above parts,
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-67760
Also USE an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Here is an average example,
http://www.radioshack.com/product/index.jsp?productId=2103245
For additional questions please post in a Comment.
Or click on Reply at end of solution, and post.
Regards,
joecoolvette
May 19, 2013 | IBM Lenovo ThinkPad R61 Notebook
Getting beep sound when i start my laptop R61, cannot start
Hi. I think the problem on your machine is the RAMS if you here the beeping sound. I would suggest that you remove the memory and clean the contact points with an eraser but make sure that you remove all the receduces and also make sure that when you plug them back you should double check if they are properly seated. If you still having the same issue after doing the troubleshooting step then try a known good memory so that you could make sure that the problem is not with the memories you have.
May 14, 2010 | Lenovo ThinkPad R61 Notebook
Lenovo R61 beeps four times and according to manual has security chip problem. Does this mean replacing the motherboard and where can they be purchased.
Oct 27, 2009 | Lenovo ThinkPad T61 Notebook
I have lenovo R61 T7100 every time i insert a
Jun 09, 2009 | Lenovo R61 T7300 Notebook
Lenovo r61
Please look here:
Communications:
Bluetooth
R61
Windows Vista
03 Apr 2008
v6.1.0.4500
v5.5.0.4300
v2.00
Nov 04, 2008 | Lenovo ThinkPad R61 Notebook
Lenovo ThinkPad R61 Notebook Logo
16 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
