Question about Fujitsu Tablets & eReaders
How to turn off noise and vibrate mode on keyboard?
How do I get my Android Galaxy Tab E to stop vibrating every 30 seconds ???
It drives other people mad as well :>)
Look at this video
https://www.youtube.com/watch?v=RQ8DLkYM9Jw
Disable Vibration Galaxy Tab Pro 8.4 - Android Forums at ...
https://forums.androidcentral.com/...galaxy-tab.../368293-disable-vibration-galaxy-ta...
Mar 6, 2014 - 10 posts - ‎8 authors
I would like to disable the vibration when I shutdown the device and the vibration all together. Can someone help me please? I Called ... New update: How do I turn off vibrate for email ...
9 Apr 2017
How Do you stop phone from vibrating when music is ...
2 Sep 2016
Any way to turn off vibration for notifications?
20 Jul 2016
How to turn of vibrate
11 Aug 2014
More results from forums.androidcentral.com
How to stop the Samsung Galaxy from vibrating - Hex Central - blogger
hexcentral.blogspot.com/2014/08/how-to-stop-samsung-galaxy-from.html Aug 8, 2014 - One of the things I dislike about my new Samsung Galaxy tablet is the way ... On other Android devices, you can disable haptic feedback from the ... For the record, my device is a Samsung Galaxy Tab 3, running Android 4.1.2.
Samsung Constantly Vibrating Fix!!! - YouTube
? 1:40
https://www.youtube.com/watch?v=RQ8DLkYM9Jw Sep 3, 2015 - Uploaded by Jimmy is Promo
If you have a Samsung device and it is constantly vibrating and you dont know why. ... my galaxy was ...
Turning off alert sounds and vibration - The Galaxy Tab Forum
www.thegalaxytabforum.com/index.php?/topic/7292-turning-off-alert...vibration/ Nov 3, 2011 - I'd like to turn off all alerts but I can't figure out how. I've only been ... Turning off alert sounds and vibration Can't get rid of continuous alerting ... See : Settings, About Device; Android Version:Unknown(SAD) - See : Settings, About Device. I'd like to ... Posted 03 November 2011 - 01:08 AM (#2) User is offline ...
How to stop conitnues vibration - The Galaxy Tab Forum
www.thegalaxytabforum.com/index.php?/topic/4195-how-to-stop...vibration/ Jun 19, 2011 - When I use my Samsung Android Tablet then it always vibrate when it keeps idle then ... Posted 19 June 2011 - 12:40 PM (#2) User is offline ...
Android Galaxy Tab to stop vibrating Google Search
Sep 22, 2017 | Tablets & eReaders
How do I connect my keyboard to my tablet
If it's bluetooth, put it into pairing mode and turn Bluetooth on from your phone. Put your phone into discoverable mode and pick the keyboard. It might take a short time to show up. Pick it, and whatever code it wants you to on the keyboard.
Oct 04, 2015 | Tablets & eReaders
How do I turn off the typing sound?
I found this nice guide that should be helpful to you.
How to Turn off Sound and Vibration in Androids Keyboard
I post on behalf of HP.
Jun 27, 2015 | Tablets & eReaders
Galaxy instruction manual
you can turn your volume down which will then only work the vibrate motor or in settings go to "sound" change sound mode to either mute or vibrate instead of sound. you can set vibration intensity to low for notifications. also under "ring and notifications" change your notification tone silent at the top of the list.
I hope this was useful
Aug 21, 2014 | Samsung Galaxy BBSPHP1 Tablet PC
How do I turn off clicking noise on my IPad?
under "settings" - "sound" you can cancel the annoying sound for keyboard click etc.
How can change notification sounds on iOS turn-off-clicking-noise-ipad-xxfkevokwfrpmirwnynhydw0-1-2.jpg
Mar 16, 2014 | Apple iPad Tablets & eReaders
Bluetooth keyboard will not connect
I'm assuming Bluetooth is turned on on the ipad.
follow the keyboard instructions to put it in pairing mode.
Then in ipad settings - Bluetooth you may need to select the keyboard.
Feb 26, 2014 | Apple iPad Mini
TF700 WON'T TURN ON
There are a couple things to try.
Possible Problem: The tablet may have gone to sleep and a newly installed app or update is preventing the tablet from coming out of hibernation.
Solution: The tablet likely needs to re-start.
The trick is to know whether your tablet is in hibernation (actually running but not screen is turned off) or if it is actually turned off.
Scenario 1, tablet is on but is in hibernation mode
1. Press and hold the power button until you feel the vibrate. Then release. Wait 3 minutes (to make sure the tablet shuts down). After the 3 minutes go to scenario 2
Scenario 2, tablet is turned off.
1. Press and hold the power button. Keep pressing even after you feel the vibration (for about 30 seconds).
Other possible solutions:
If that does not work, then ...
2. Disconnect the tablet from the keyboard and press and hold (same as step 1 scenario 2).
3. If the others methods do not work, connect the tablet to a PC (with internet connection). Leave the tablet connected for a minimum of 30 minutes, but upto 2 hours. With the tablet connected to the PC, press and hold the power button (same as step 1 scenario 2).
If none of those worked, connect the tablet to a TV or monitor using the HDMI connection. If the TV/monitor displays the tablet, then use the display on the TV to reset to factory defaults and force a re-boot. While it is shutting down, disconnect from the TV.
If that does not work, check the user manual for how to reset the tablet to factory default settings.
Last but not least, contact Asus support because you might have to send it for service. But I suspect scenario 1 will work for you.
Feb 12, 2014 | ASUS Transformers Pad Infinity TF700TWIFI...
Keyboard not recognized
could be stuck in number function mode, or the keyboard has just got bad all together,
might need replacing.
plug in an external keyboard, to be sure, the cpu/motherboard could be bad.
Jun 10, 2008 | Tablets & eReaders
Tablets & eReaders Logo
23 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Tony
Tony
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
