Question about RELIANCE ELECTRIC WATER HEATER
How many gallons are ther in a reliance 501 water heater
  • 2,005 Answers
As near as I can see you have a thirty gallon tank.
Posted on Dec 17, 2014
muttandjeff
  • 359 Answers
SOURCE: I have a Reliance 501 gas hot water heater that
hook up garden hose to faucet @ the bottom of the tank and drain the hose to the outdoors or down a floor drain and open the valve , leaving the cold supply valve on , let it run until it runs clear , this will get rid of some of the sediment deposit that form at the bottom of tank , is the most effective way i know , good luck
Posted on Dec 31, 2009
  • 127 Answers
SOURCE: I have a reliance 501 electric hot water heater
it is located on the thermostat. Take the cover off the side and you will see a little red button in the side of the themostat.
Posted on Jan 11, 2010
  • 82 Answers
SOURCE: need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
Posted on Jan 31, 2010
garypetterss
  • 15 Answers
SOURCE: I have reliance 501 electric hot water heater, and
There is an address near the end of this link to request manuals of reliance water heaters not listed. http://www.reliancewaterheaters.com/lit/om.html
it is quite possible that your heater works on the same principle as one of the other models and just differs in capacity or power rating.
Posted on Apr 11, 2010
SOURCE: I have a Reliance 501 water heater, when I take a
Electric water heater is fully repairable by homeowner.
Following information will tell you how.
1) Background on your heater:
Reliance is AO Smith company.
http://www.aosmith.com/OperatingUnits/Detail.aspx?id=138&ekmensel=c580fa7b_12_0_138_3
Age of water heater is shown in serial number. First character is letter. Second 2 characters are numbers, which are year of manufacture. For example 05 is year 2005.
The 501 manual is not shown on Reliance website:
http://www.reliancewaterheaters.com/prod/elec.html
2) Two things known for sure:
- electricity is OK
- upper element is working because there is some hot water.
3) Three things can cause problem you describe:
- Loose wire located from upper thermostat to lower element and thermostat.
- Upper or lower thermostat is bad
- Lower element is burned out
4) How to troubleshoot and repair
- Turn off power, open covers and look for loose and burned wiring, especially on lower element.
- When finished, put back insulation and covers so thermostat not exposed to cooler temperatures.
- Burned wire on lower element is evidence that lower element is burned out.
- If you do not want to follow testing steps below, next step is to replace both upper and lower thermostat for about 25$ and see if problem persists.
- If problem persists, replace lower element.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) Test lower element, before replacing anything
http://waterheatertimer.org/How-to-test-water-heater-element.html
6) Troubleshoot electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
7) How to replace lower element and clean sediment out of tank:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
Posted on Nov 18, 2010
Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
I have Reliance electric water heater 501: 40 gallon, 2x4500w. Where do I buy the bottom heating element? I went to the plumbing store and get one but it is a little smaller than the old one. why? I am...
Your water heater has two 4500 watt elements so water heater is 240Volts, and water heater is rated 4500 watts. Both elements are not ON at same time, and this is called non-simultaneous operation.
The element might have been smaller in length, but it will work fine.
Why is it smaller. I don't know. Elements are different from manufacturer to manufacturer.
The 501 does not use a special element.
Local box stores and hardware stores sell elements in water heater department.
The wattage of element is printed on end of each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 20, 2011 | RELIANCE ELECTRIC WATER HEATER
I cant seem to find were the gallon size is on my reliance 501 electric water heater were might it be located?
Look at label on side of tank.
Other useful links:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
http://waterheatertimer.org/Replace-anode-rod.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 25, 2011 | RELIANCE ELECTRIC WATER HEATER
I need to know if i have the right element for my water heater. i have the reliance 501 4500w/240v id # 5 40 2ort0 w i want to know if i need the long 1 or the bent 1. would love a pic if possible. i...
Either element will work ... straight or bent.
4500 Watt element will work, buy you can also substitute 3500, or 1500 Watt.
Stepping up wattage larger than water heater nameplate is not recommended, because wiring may not carry more watts.
Element wattage is printed on end of each element.
Reliance 501 manual is not available on Reliance site.
The 501 used to be standard model, but now it's the 600 series.
600 series manual is similar to your product.
page 22 shows element replacement, and says not to use greater wattage than rating plate on water heater.
http://www.reliancewaterheaters.com/lit/om/manuals/185761-000.pdf
Age of Reliance heater is on serial number. First character is letter. Next two characters are numbers corresponding to year. So C05222,,, serial number is made in 2005.
Nov 19, 2010 | Reliance Better Water Heater Element
I have a Reliance 501 40 gallon water heater leaking warm water from the valve at the top of the unit. Steady leak. What should we do short term, and is there a part we can get to fix it?
i am not sure if you are talking about a shut off valve or the pressure relief valve. the relief valve should have a pipe from it going down the side of the water heater. if that is the leak the it can be replaced. there should be a little lever on top of it and some times by lifting it and letting a little water flow through, it will stop leaking.
Oct 19, 2010 | Reliance & 50gal Electric Water Heater
Need to empty reliance 501 hot water heater how?
Jan 26, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a reliance 501 electric hot water heater and i cant find the reset button. Where is it located?
Jan 10, 2010 | RELIANCE ELECTRIC WATER HEATER
RELIANCE ELECTRIC WATER HEATER Logo
177 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
