Question about AO Smith Plumbing
ORM5458 three wire hook up
How to hook up a two wire toggle switch to a 1987 Yamaha virago three wire key switch
you would need two 2 wire switch's as one wire feeds switch , one feeds ignition and one feeds starter to start on momentary
May 16, 2015 | Yamaha XV 535 Virago DX Motorcycles
How do i hook up a 4 wire timer switch (R G B W) to a three wire box(G B W)?
Generally your hook up is like this.
G - Ground - Green or bare wire
B - Hot - Black wire
W - Neutral - White wire
R - Switched - Hot when on
On your three wire
B - Hot - Black wire - hook to switch wire from switch
you should also check: http://www.intermatic.com
Jun 04, 2010 | Intermatic EI210 Electronic Auto Shutoff...
Where to connect three wires
You should have:
one wire from the compressor that will hook to "HERM".
one wire from the fan motor that will hook to "FAN"
one wire from the relay ("hot" wire") will hook to "C".
Apr 14, 2010 | Fedders Y Chassis A6Y12F2A Air Conditioner
Need a basic diagram to wire a ceiling fan.
Depending on how your place is wired will dictate the solution here.
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Hunter 52" Ceiling Fan With Light And...
WIRING DIAGRAM
Sep 18, 2009 | Panasonic FV-08VQL4 Fan
Plumbing Logo
22 people viewed this question
Top AO Smith Plumbing Experts
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
