Question about Craftsman Briggs & Stratton Generator, 3600 Watt 7 HP
Stalls after 10 min
Will not run after 10 min under load
I have a 03 kia sorento that i just changed the timing belt and water pump on. It drove fine for about 10 mins but then stalled. After 15 mins it starts, runs for 10 mins, rough again and stalls out.
run fault codes
check for wiring on crank shaft position sensor or cam position sensor/s
it will be something that was affected by the belt replacement procedure
Feb 14, 2017 | Kia Cars & Trucks
Sears lawn tractor
Check fuel tank or cap vent to be sure it is not plugged.
May 03, 2013 | Garden
Accent 2000 runs well then stalls once hot and will not start till cooled off
Check your coolant level and overflow bottle for proper fill. Or try running it With radiator cap loose to see if it still stalls. If it still stalls and coolant levels are good you need to check temp sensor. May be more than One. If you did install a new one, it may have been faulty or damaged. If all that fails then try an idle positioning sensor. The spring may be worn.
Sep 24, 2012 | Cars & Trucks
Husqvarna ride on will quit after running for about 10 to 15 mins.
check for spark as the coil might have gone bad
Aug 15, 2012 | Garden
Suburban stalls while driving after running for 15-30 minutes. After letting it sit for 5-10 min it runs fine for another 5-10 minutes, then starts doing it all over again.
a bad crank sensor can cause this. shuts off while going down road, and will start about 10 min, later with no problems runs fine until it quits again. hope this helps,
Oct 07, 2009 | Chevrolet Suburban 1500 Cars & Trucks
RVP 8000 Series Compressor wont stay running.
Try shutting everything else off temporarily that would draw any hydro in the unit, or even shut off all breakers except AC, and see what happens. See if it runs longer with everything else off. Double check nothing else on same circuit as your AC, and also confirm that 12/2 & not 14/2 cable size used for AC.
Jul 20, 2009 | Coleman Mach 15 Air Conditioner
Stalling
Check your batteries, they might be ready to die. Stalling is a sign your are not getting enough power to the scooter and when you do, it runs until they run low again. Kinda like a cell phone batt, ones it dies and you wait awhile you can get it started but only for a couple of minutes before dying again.
Apr 14, 2009 | Echo 3 TE SL7 3 New Electric Scooter by...
Craftsman Briggs & Stratton Generator, 3600 Watt 7 HP Logo
19 people viewed this question
Top Craftsman Electrical Supplies Experts
wadingriver
wadingriver
ray gallant
Steve Pack
Steve Pack
Are you a Craftsman Electrical Supply Expert? Answer questions, earn points and help others
