Question about Toshiba Satellite P100 Notebook
Vertical Lines on Screen
I have 2 vertical lines that have appeared on the screen of my Toshiba P-100 laptop. What is the reason and how can I fix the problem
    Scholar:
  • 124 Answers
Either the cable has come loose, or the display is going out.
I would call Toshiba and see what warranty is left ...
Posted on Jun 23, 2009
I have vertical lines (15 of them now) on my Toshiba laptop.
I'm afraid when you see vertical line on an lcd panel, it most likely is screen failure. Ebay has plenty of screen from good companies in Texas. I get most of my screens from Ebay store LCDTECH99. They have the best prices, most screens are under 100 bucks and they ship right away. The Toshiba screen is an easy repair, Only the bezel needs to be removed in most cases. Below is a guide to show the process.
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
Nov 27, 2009 | Toshiba Satellite P105-S6227 Notebook
Vertical lines on laptop monitor
This would need a screen replacement
Lots of people do this themselves
Ebay is a good source for laptop parts most of which are NEW
Aug 26, 2009 | Computers & Internet
Vertical lines appearing on my laptop screen
...not good. Generally means your screen is on it's way out.
Jun 22, 2009 | Compaq Presario M2000 Notebook
Thin Vertical lines on the screen
Ebay - new screens $110-$135. Google for step-by-step replacement instructions.
Dec 30, 2008 | Toshiba Satellite P30 P35 Series Notebook
Vertical lines in my laptop screen
This could be a failure in several areas along the path from the video card to the monitor.
Being that there is not an issue across the entire monitor the video card should be considered a last resort check.
Usually this is caused by a loose connection between the LCD driver and the LCD panel itself. Sometimes light pressure applied near the affected line will clear it up. If that does then it is a connection between the LCD panel and the connector to the LCD driver at the panel's edge.
Not much can be done unless you have it repaired by a professional or you can take it apart yourself and apply a pad of some type inside the monitor's edge to apply the needed pressure once assembled.
Aug 11, 2008 | HP Pavilion dv8000t Notebook
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
May 04, 2008 | Dell Inspiron 6400 Notebook
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Feb 06, 2008 | Toshiba Satellite P35-S609 Notebook
Open Questions:
Toshiba Satellite P100 Notebook Logo
351 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
