Question about Canon P23-DH Calculator
HOW TO CLEAN A DIRTY INK ROLL? - Canon P23-DH Calculator
2 Suggested Answers
SOURCE: paper comes out dirty
I has been sorted it! I just print empty documents so it get better. I am having a look now  to know if the problem comes back!. However thanks very much because the forum is very helpful.
Posted on Nov 07, 2008
How do i clean my printer after I change the ink roll?
What does this mean? "ink roller". I''ve never have never heard the term. Does you mean ink ribbon roll? Why would you need to clean anything with that type?
Sep 02, 2014 | Polaroid P3500S Id Card Printer System
NUMBERS ARE NOT LEGIBLE FROM PRINTER
Problem solved. Took the cover off the ink cartridge well. The printhead cylinder was exposed. Cleaned it with rubbing alcohol, nonmetallic brush, and noncotton swab. The printhead can be rotated away from you with the power off, not toward you. The printout is like new now.
Dec 03, 2013 | Canon P170-DH Calculator
HP T1100 paper load incorrect
Check:
1. Was its sensing the paper while loading the media?(roll or sheet)
2. Perform 'service test for sensors' to know how media sensor is working.. if its fails clean media sensor located left side of carriage assembly. If the media sensor becomes dirty due to ink, printer unable to detects the medias edge. Clean sensor gently.
Entering in service mode: Power off the printer using from the operational panel off button. Press & hold up arrow,ok button switch on the printer, wait few seconds to enter in service mode, once its enters in service mode, scroll to sensor test.
Nov 28, 2012 | HP Designjet T1100ps Printer
Replace ink cartridge
If the ink cartridges are brand new and you get this error then take it back to the store and demand a replacement. If your ink cartridges have been running a while then chances are that they are dirty...
Gather cleaning supplies:
Clean distilled water. Use bottled or filtered water if distilled water is not available.
Clean cotton swabs or any soft, lint-free material (coffee filters work well).
Remove both cartridges.
Unplug the printer.
Lightly moisten the lint-free cleaning material with clean water.
Clean the cartridge contacts. Avoid touching the nozzles. Replace the cleaning material if it gets dirty.
If that does not work then I would try ordering some new cartridges from a trusted source.
CANON PIXMA INK CARTRIDGES
Sep 12, 2012 | Canon PIXMA MP240 All-In-One InkJet...
Installing ink cartrage in a royal 435dx cash register
1. Open the printer compartment by lifting the black, plastic printer cover.
2. The ink roll is found in the front of the printer compartment, just behind the print
head, and is mounted in a plastic cartridge.
To remove, grasp the small clip on the left of the ink roll (where the words "PULL UP" may
be printed on the ink roll cartridge) and pull up.
The ink roll will easily pull up and away from the print head.
3. To replace a new ink roll, insert the ink roll according to markings "L" (Left) and "R"
(Right) by pressing downward to lock it into position, then close the printer cover. No tools
are necessary.
For best performance, store unopened ink roll package in a cool, dry place until installed.
NOTE: Replace with ROYAL Ink Roll, Part #013109.
Nov 16, 2010 | Office Equipment & Supplies
Lex 5150 - not printing black well
what you may have to do is clean the rollers, good place to clean is where you insert the cartridges, open the lid so the machine thinks your going to repalce the ink, cut the power from the mains, now you can proceed to to clean the inside, remove both in cartradges and clean where they instert, toilet roll or kitchen roll will do because they soak up the ink, then, and be very gentle, slide the mechanism to the left hand side so you can clean underneath, after cleaning power the printer up so that it still thinks you are changing the ink, the cartridge housing should be where you can access them so you can the put the ink back in, then you need to use the the lexmark software to re-align the cartridges and also print a test page, keep on doing this until the inkjets are performing properly
Nov 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Paper comes out dirty
Nov 06, 2008 | Canon BubbleJet i70 InkJet Photo Printer
Question
1) For a copy to be blurred: either you need to add more ink (Toner) or you need to increase the toner density
2) When you have dirty copy: Try to clean your glass and the glass cover and also clean the mirrors inside and the zoom/lens.
3) a dark dot: you have to bring out the drum unit and roll it round you may be able to see a spot on, clean it with a fry cloth and fix it back to its position.
May 08, 2008 | Office Equipment & Supplies
New ink roll in Philips fax Magic 2
Have just tec support (10p per min robbers !!)
Here is what you do
OPEN MACHINE
WITH THE NEW INK FILM IN, ROLL THE INK FILM ON ROLLER NEAREST TO YOU FORWARD UNTIL ALL THE SILVER STRIPS TO THE RIGHT ARE NO LONGER VISIBLE (THIS IS THE BAR CODE ON THE INK ROLL IT'S SELF)
REMOVE INK FILM FROM MACHINE
CLOSE MACHINE
TYPE IN OK 45 OK 7117 OK (THEN IT WILL ASK IF YOU ARE SURE) YES (CHANGE WITH < > BUTTONS BETWEEN OK BUTTON )
SET TIME AND DATE
OK
OPEN MACHINE
PUT INK FILM BACK IN
CLOSE MACHINE
YOUR DONE LOVERLY JUBBERLY !!!
HOPE THIS HELPS AS IT DROVE ME MAD Rob
Apr 04, 2008 | Philips PPF-531 Plain Paper Thermal...
How do i take out the ink thingy
You will need: 1 Replacement ink roll - Porelon PR42 Ink Roll (This roll will replace the black and red ink all on one roll) Available at OfficeMax or other supply stores.
You must first remove the clear plastic cover on top of the calculator (where the tape comes out). Remove the old ink roll. You will see on the roll where it says "pull up". It will pop out easily. Replace it with the new ink roll, it will just snap in place. Replace the clear plastic cover. It should now be ready to go!
Mar 28, 2008 | Casio FR-2650Plus Calculator
Canon P23-DH Calculator Logo
113 people viewed this question
old marine
old marine
