Question about Swann Communications DVR4-Alert Video Recorder
NVR4-7200 Remote is locked it will not allow setup...? To do
Digital tv channel stuck on Setup blue screen
Just contininue to try that it if not then you'll have to do a hard reset.
Feb 01, 2014 | Philips Televison & Video
Hi, I have just got this t.v, braught it second hand and came with no remote. I can seem to install it with a universal remote or by just the buttons on the tv, do you have any suggestions? Also what is...
If the buttons on the panel of the TV do not works at all, it might be panel lock function energized. If you want to unlock the panel lock function, you must have its original remote control. No universal remote control will go.
But, you can synchronize this TV with a universal remote control, even though its panel lock is ON. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check out, which brand remote control has setup codes to your TV/Device brand. Setup code list & setup procedure to some popular brand remote controls are given. Check it, and determine which brand remote control should be bought, and buy that brand remote control, according to availability.
for more information go to:
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Nov 11, 2013 | Televison & Video
How do I run setup without remote
you need the remote---an original remote.
Mar 25, 2012 | JVC LT-26WX84 26 in. LCD HDTV
I have a GoVideo DVR 4300 that has been child locked. I have lost the remote control. Is there any way to unlock it with out the remote?
According to page 16 of the owner's manual, you cannot disable child lock without the remote. Because you have lost the remote, the unit does not offer a manual way to disable that feature. I am not sure if a universal remote will allow you to enter the setup menu, and turn the child lock OFF. You could try that - it might work.
Or you could try contacting them:
Phone (480) 922-0896 or (800) 736-7679 (during business hours)
E-Mail customersupport@sonicblue.com
Web www.govideo.com or www.sonicblue.com
They may or may not be able to offer further assistance. The universal remote might help, if you cannot get the original replacement for your unit.
Personally, child lock in DVD players is a pointless and unnecessary extra feature that should not exist; it should really only apply to Blu-Ray/DVD recorders.
May 06, 2011 | GoVideo DVR4300 DVD Player/VCR
My remote won't allow me to turn on our TV but after I turn the TV on, the remote allows me to change the volume and mute but will not allow me to change channels.
I would re-program the remote. I don't belive this is the exact correct code. Some codes kinda work but no fully. That's when it's time for another code for your brand or use the setup and power auto-code search
Apr 08, 2010 | Philips Televison & Video
Incorrect regional code
1.Switch on unit
2.Press- Setup on the remote
3.Select the Lock option from the on screen setup menu
4.Press 0 x 7 times on the remote keypad
5.A message appears stating the unit is now Code free on the screen
6.Press Enter on the remote.
7.Close Setup menu and switch unit off.
8.Switch on and enjoy Multi-region DVD playing on your LG RC199H (RC7000)
Mar 27, 2009 | LG RC199H DVD Recorder/VCR
I need to change my DVD players Region code to play all regions.
1.Switch on unit 2.Press- Setup on the remote
4.Press Lock on the remote unit ( under slide cover)
5.Press 0 7 times on the remote keypad
6.A message appears stating the unit is now Code free on the screen
7.Press Enter on the remote.
8.Close Setup menu and switch unit off.
9.Switch on and enjoy Multi-region DVD playing
please donot forget to rate this solution.
Thanks for using FixYa.
Jan 28, 2009 | LG RC199H DVD Recorder/VCR
I need remote control code number for motorola dvr 6416 III
If this is a remote by UEI or Atlas (usually the black remote that the cable company supplys with the box) the code is 1376.
To set the code, you will need to do the following:
Unlock the Cbl button:
Press CBL once. it will blink once.
Press and hold SETUP until CBL blinks twice. Release setup
Press 982
CBL will blink 4 times, indicating it is unlocked
Program the code in:
Press 1376
CBL will blink twice if the code is accepted.
Re-lock the CBL button:
Press 982
CBL will blink 2 times, indicating it is locked again
If it is not a UEI or Atlas remote, let me know the remote make and model
Dec 01, 2008 | Arris DCT6200 DTV Receiver
Require region unlock code for LG RC389H
1.Switch on unit
Oct 19, 2008 | Televison & Video
Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Dec 08, 2007 | Televison & Video
Swann Communications DVR4-Alert  Video Recorder Logo
56 people viewed this question
Top Swann Communications Televison & Video Experts
Lawrence Oravetz
Jack Frost
Jonathan Ashkenaze
Jonathan Ashkenaze
Are you a Swann Communications Televison and Video Expert? Answer questions, earn points and help others
