Question about Garden
How to install throttle spring on husqvarna model 325-xl grass trimmer
steve_lima
  • 181 Answers
SOURCE: what are the timing specs on a Husqvarna 36-r string trimmer
there is no timing spec . the air gap is .010 to .012. or .254 mm to .305 mm.open the gap all the way up and tighten the screws.bring the flywheel magent to the coil making sure that both sides of the coil is on the magnet.slide the gapping tool in and the magent will hold it in place.once it's there release the screws holding the coil and the magents wiil pull the coil to it.once it's there retighten the screws and your done.
Posted on Mar 12, 2009
#1 Taper
  • 1040 Answers
SOURCE: Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
#1 Taper
  • 1040 Answers
SOURCE: NEED INSTRUCTION SHEET FOR LINE INSTALLATION
If it is a duel line trimmer then:
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Posted on Dec 02, 2009
rycgl
  • 1545 Answers
SOURCE: 325 X-L trimmer throttle doe not operate.
There should be a small recessed area off to one side inside the handle for the routing of the throttle cable...Look closely. The spring that controls the return on the trigger isn't too complicated either. It has to be held in place somehere on the throttle handle also and may have to be preloaded so there is tension on it when you install it..Look around closely in the area in the handle RIGHT above the trigger.
Posted on Jul 12, 2010
I need instuctions on how to put back the throttle assemble for a husqvarner 223L trimmer
Hello Ronny
I'm not fully familiar with that model however I have found a diagram that may help you. The image is a little small but it may give you an idea of the springs location.
May 12, 2014 | Husqvarna 223L
Husqvarna 25r - is this a good model?
The 25R was a badged engineered machine ( not made by Husqvarna ) the first model was a Mitsubushi engine, the later version was a Mariama, both were good machines in there day, they were offered with a line head and a grass blade, they were as you can guess approximatly 25cc, the early version had points condensor ignition, and later on had electronic, parts are now becoming hard to get, so be aware.
May 14, 2013 | Garden
Is there a brush cutter kit for a 125L Husqvarna grass trimmer?
Brushcutter kits should fit this model however it is quite a small engin within the range so may not be advised and it could put extra load on the engine and drive shafts
Nov 29, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
How does the spring attach under the throttle on husqvarna whipper snipper
What is the model number, I'll send you the Illustrated Parts List
Sep 17, 2011 | Husqvarna 28cc Gas Line Trimmer
Jul 11, 2010 | Husqvarna Forest & Garden 125c 17"...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
