Question about Ford 8N Tractor
How do you know if a tractor has been converted to 12volt system
  • 653 Answers
A 12 volt system will have an alternator instead of a generator, a 12 volt ignition coil, and most importantly a 12 volt battery.
Posted on Aug 23, 2014
  • Fahr Quad Aug 23, 2014
    Oh, and a 12 volt system will have a negative ground instead of a positive ground.
Show me how to wire farmall cub tractor when converting from 6 volt to 12 volt. It's a 1951 farmall cub
Replace the coil with a 12volt coil. Replace the generator with an alternator. Replace any light bulbs with 12volt. Fit the new 12volt battery in with the negative terminal to chassis! and there you have it.
Feb 02, 2017 | Farmall Garden
I WANT TO CONVERT MY SCOOTER FROM 36 VOLT TO 12 VOLT HOW CAN i CHANGE MY 36 V. CHARGER TP 12 VOLT
This will need a motor change as well which is a pity and pressume that you have looked into that already.
Simply if you already have 3 12volt batteries you can charge in series and use just one in scooter or you can purchase a ordinary car 12volt charger for a cheap price an there are advanced units that give good deep charge automatically
Nov 07, 2014 | Health & Beauty
Wiring Diagram For 12Volt Monster Trax Convertible Car 12-Volt Battery-Powered Ride-On
type: redman 12v red convertible schematics or wiring diagrams search google images I found the pics!
Sep 20, 2013 | 12Volt Monster Trax Convertible Car...
Tractor will not turn over. Replaced solenoid. This 1964 Ford 4000 has been converted to a 12 volt. I have replaced broken wires and tested the key switch and strater button and battery tested good bu
use jumper cables and put power dirrect to the starter and see if the starter is any good next put power to the small terminal on the solenoid that small terminal triggers the solenoid a lot of times when these a converted to 12volt the starter doesn't get changed out til it fails and 6 volt starter are not happy with 12 volts
May 20, 2012 | Ford Garden
What volt battery for craftsman tractor model 917276240
all riders take a 12volt battery . you can buy the smaller lawn and garden battery for around 30$ my suggestion is get the bigger battery that is offered specially if going to use the rider during winter and it has a twin cylinder . it give you more power for faster starts and is easier on the charging system .
Nov 24, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Ford 9n converted to 12 volt alt still 6 volts at dis. runs rough till i jump 12 volts to coil and then it runs good. Will this damage coil and points?
If you are doing 6 Volts at the distributor you must either have Resistor wiring or a separate resistor in the system. They make both 6Volt and identical 12Volt coils for your unit.
You will eventually burn up a 6Volt coil if you use 12Volts on it. There is an aftermarket company which has Antique supplies. Carpenter(Maybe John) has supplies for Tractors, cars and trucks that are earlier models.
Do a Web search using his name and marry it to Tractor parts, etc.
Sep 09, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
Peg Perego John Deere tractor 12volt will only work in reverse. Will not go forward in the slow or fast speeds
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
Aug 16, 2009 | Peg Perego John Deere Turf Tractor
Wiring diagram
See if this link is of any help. I know how crazy these new wire colors can be. I don't know why they don't keep it simple and universal meaning all constant power be red, alt power blue/white, ground black, etc. etc. Even my Hyndai has crazy wires. my red is lf speaker, yellow, lr speaker, etc. Goodluck with it man.
http://64.85.6.118/diagrams/diagrams.asp
May 21, 2008 | Car Audio & Video
Ford 8N Tractor Logo
79 people viewed this question
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
