Question about Homelite Mighty Lite Lawn Trimmer
Install new throttle spring on my husqvarna 325-xl grass trimmer
3 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
SOURCE: My Homelite grass trimmer idles fine but when I
Give it 10 seconds run on middle choke turn it to run and dab the throttle on and off as quick as you can until it runs normally. Helpful in the cold too .
Posted on Jul 29, 2010
I need instuctions on how to put back the throttle assemble for a husqvarner 223L trimmer
Hello Ronny
I'm not fully familiar with that model however I have found a diagram that may help you. The image is a little small but it may give you an idea of the springs location.
May 12, 2014 | Husqvarna 223L
Hi. I inherited a 1998 Husqvarna 265 rx. Got new plug and new fuel and it fires ok. Wouldn't stop so I added a washer under the 'earth' screw and it now stops. Problem is poor acceleration
To set the throttle, start by slackening the cross head screw securing the cable in the handle and pull completly out, now slacked the three allen headed screws securing the handle, twist the handle to the best position for your use ( at full throttle your thumb should not be straining ) now slacken the lower cross head screw and turn the silver clamp to tention the spring underneath, when correctly adjusted the throttle trigger should spring back to the idle position readily, now re fit the cable up through the clamp, turn the cable so as it is just about to open the carb throttle spindle, lock the cross head screw and test to make sure you are getting full throttle, if not slacken the screw and turn cable a little more.
Sep 19, 2012 | Husqvarna 531004054 Throttle Wire
How does the spring attach under the throttle on husqvarna whipper snipper
What is the model number, I'll send you the Illustrated Parts List
Sep 17, 2011 | Husqvarna 28cc Gas Line Trimmer
Engine start procedure for grass trimmer 350 L x series
  • With the trimmer placed on a level piece of ground press the primer bulb about 10 times.
  • Open the choke.
  • Press the throttle and lock it in place with the lock button
  • Pull the start cord until the engine catches. It doesn't matter if it cuts out again.
  • Close the choke, and if the engine did cut out the first time, pull the start cord again. This time it should start and you can start trimming the grass. If it didn't cut out just close the choke and you're ready for trimming.
Apr 06, 2011 | Husqvarna Garden
I was given a grass petrol strimmer and the pill cord spring and cord are broke. can fix myself just need to know where to get parts. living in ireland
Really simple to fix, easily done yourself if you know wtah your doing. Parts are available from your local husqvarna dealer
Jan 27, 2011 | Husqvarna Forest & Garden 125c 17"...
325 X-L trimmer throttle doe not operate.
There should be a small recessed area off to one side inside the handle for the routing of the throttle cable...Look closely. The spring that controls the return on the trigger isn't too complicated either. It has to be held in place somehere on the throttle handle also and may have to be preloaded so there is tension on it when you install it..Look around closely in the area in the handle RIGHT above the trigger.
Jul 11, 2010 | Husqvarna Forest & Garden 125c 17"...
Homelite Mighty Lite Lawn Trimmer  Logo
24 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
