Question about GE Refrigerators
Ge gss25wstss ss icemaker auger motor U Bracket
4 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: icemaker auger jams , GE side by side
Water expands when it freezes and you probably have too much of it when the mold tray fills... Readjust the level to a bit less and you won't have triplet or quadruplet ice cubes..
Hope that helps...
Posted on Aug 20, 2008
SOURCE: GE Profile Ref. Ice despenser motor does not turn. Auger turns
I had this same problem today, and after tearing apart the door and digging with the multimeter, I found that the bulb was drawing to much current {probably due to age} and that pulling it made everything else start working. The high resistance was drawing too much current from the IC on the door panel board.
I'm going to get a new bulb tomorrow, but if you yank the bulb it'll probably work. {If you have the same problem}
Posted on Dec 03, 2008
  • 31 Answers
SOURCE: My GE Model #GSS25WSTSS does not dispense ice from
you are going to have to bend it to fit,
Posted on Sep 29, 2009
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
I have a GE Profile Artica. Dispenser is not dispensing ice even though ice bin is full. When i press the for ice to dispense , the light dims and the compressor stops.
Try taking out the ice bin press the door light switch and dispense ice button at the same time and see if the motor bracket turns without the ice bin in place. It is possible you have ice in the bottom of the bin that is frozen and jamming the movement of the auger. If not the problem may be a defective auger motor=> WR60X10259 Auger-Motor
I will be here should you have questions, Sea Breeze
Mar 01, 2013 | GE Refrigerators
Ice maker dispenser gets stuck. auger will not turn in the ice bucket. motor that drives auger tries to turn, but something in the front of of the auger/dispenser prevents it from turning.
I have this identical unit and have had this identical problem. What we do is remove the entire ice container from the refrigerator and shake it to break up the ice inside or we remove large chunks of adjoined 'cubes' and replace the entire tray/container and it has worked fine for us thereafter.
Feb 02, 2011 | GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side...
My ice maker makes ice but will not dispense it
When you push the lever to dispense ice, can you hear the motor running? If not, that motor might be dead and not turning the auger, which would be your problem.
If you can hear the motor and auger turning, the chute or the opening in the ice maker might be clogged up with ice. Clean the entrance to the ice maker and the chute in the freezer door and that should fix your problem.
Dec 13, 2010 | GE Monogram ZDI15C Automatic Icemaker
Have a SS #GSS22WGPEWWW Ice not coming out
Try taking ice pan with auger out hold door open and press light switch for the door in while someone presses dispense ice. I want to see if the motor is turning behind the auger ice tray. The door switch has an interlock and when door is closed the dispenser controls should be functional. When open this disables water and ice dispenser. waiting on your response, Sea Breeze
Jan 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser doesn't work
You need to replace the motor and the " U " piece that screws onto the motor . You may have to saw the motor shaft , to remove the motor , if the U piece will not screw off . Remove the panel which holds the motor ( 4 screws ) and disconnect the plug , and the whole panel should come out .
Auger motor pt. # WR60X10258
Auger drive pt. # WR02X11941
Sep 29, 2009 | GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side...
GE PSS26GRE SS not dispensing ice
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Disassembly of ice tray to replace icemaker auger
on sidebyside the tray should just pull out
Jun 26, 2009 | GE Refrigerators
Ice will not dispense GE model GSL25IFRF BS
well if you trouble shoot the board at the back to see if you are getting voltage if you are then use a jumper on that conenctor and see if the auger motor runs or remove auger motor and check voltage there while pressing the lever for ice usually 100% of the time that board controls everyhting water and ice
Nov 17, 2008 | Refrigerators
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
