Question about Microwave Ovens
Manual for kenmore central vac 108-34544 - Microwave Ovens
Manual for 900W; Ser#5x7x026575; Model #565.8948090 mfg. in Nov. 1995
Hi mary28ok,
There's no available PDF download online for the user's manual. However, you can still get the manual by calling Kenmore's customer support directly. They can send through email the specific user manual you need. Just provide them the model number 565.8948090. You may call them at 1-888-KENMORE
(1-888-536-6673).
Hope this helps.
Thank you for using FixYa.
Sep 13, 2011 | Kenmore Microwave Ovens
I need a manual for a kenmore microwave oven 66222
Sears has pdf manuals for all Kenmore appliances at managemylife.com.  No need to register or anything there, just search for the model number.  Here's the link to the manual:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0520944.pdf
I just uploaded the manual to the FixYa.com page for this oven, so it should also be available here in the next couple of days.
Jul 16, 2011 | Kenmore 66222 Microwave Oven
I just bought an 1100 watt microwave oven from K-mart and when I opened th box there was no manual in the box. The microwave number is 66222. how can I get a manual
Many Kenmore appliance manuals are available from Manage My Life. com . The Kenmore 66222 manual is here: http://www.managemylife.com/mmh/owner_manuals/23454/KENMORE-Countertop-Microwave-L0520944?brand_name_search=Kenmore+66222 . A printed copy is available from Sears Parts Direct: http://www.managemylife.com/mmh/owner_manuals/23454/KENMORE-Countertop-Microwave-L0520944?brand_name_search=Kenmore+66222 . Scroll down for the manual; it's the fourth from the bottom.
Unless the microwave was labeled as a refurbished or open box unit, I'd contact K-mart customer service and see if they'll send you a replacement manual before you order one.
I hope this helps.
Jul 15, 2011 | Kenmore 66222 Microwave Oven
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
Jul 09, 2011 | Kenmore 80809 Microwave Oven
Is there a service manual available for Kenmore Deluxe Water Purifier Model No. 34481?
Is this the right unit: http://www.managemylife.com/mmh/owner_manuals/14410/KENMORE-Reverse-osmosis-L0312270?brand_name_search=Kenmore+34481 ? The parts list and owner's manual are available but the the parts blow up doesn't show where the parts fit. The link to the parts list is on the right hand side of the page. No additional service manual appears to be available from Sears/Kenmore.
I hope this helps.
Jan 01, 2011 | Kenmore Microwave Ovens
Le moteur de mon aspirateur duo vac model 3200 refuse de démarrer, cette aspirateur à plus de 10 ans et a toujours fonctioné, La semaine dernière le moteur a...
Bonjour M. Grenier, le probleme ce situe dans la carte électronique de votre aspirateur central Duo Vac. C'est probablement le relais qui est défectueux. Il peut rester en position ''on'' ou autant en position ''off'' lorsqu il devient capricieux. Contactez nous au www.aspirateursenligne.com pour des renseignements et les pièces
Bonne chance
Nov 16, 2010 | Microwave Ovens
Sears / kenmore Is there an operating manual on line
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
You can just enter your full model number at the
Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
May 13, 2010 | Kenmore 63792 Microwave Oven
Go to managemylife.com and type in your model number under the "Manuals" link. Your owner's and installation manuals should be available in a .pdf (Adobe) format that you can download or print for FREE.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 23, 2010 | Kenmore 63792 Microwave Oven
Manual
RE: Kenmore Microwave Model 5668878411 "Instruction Manual"
Kenmore Customer Care @ http://www.kenmore.com/shc/s/nb_10154_12604_NB_CustomerCare?adCell=AF
Click on the above link to order a manual or download a free manual.
jackiaria
Mar 01, 2009 | Kenmore Microwave Ovens
Microwave Ovens Logo
180 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
