Question about Craftsman Garden
How to install throttle spring on 325xl husqvarna grass trimmer
steve_lima
  • 181 Answers
SOURCE: what are the timing specs on a Husqvarna 36-r string trimmer
there is no timing spec . the air gap is .010 to .012. or .254 mm to .305 mm.open the gap all the way up and tighten the screws.bring the flywheel magent to the coil making sure that both sides of the coil is on the magnet.slide the gapping tool in and the magent will hold it in place.once it's there release the screws holding the coil and the magents wiil pull the coil to it.once it's there retighten the screws and your done.
Posted on Mar 12, 2009
#1 Taper
  • 1040 Answers
SOURCE: Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
SOURCE: My Homelite grass trimmer idles fine but when I
Give it 10 seconds run on middle choke turn it to run and dab the throttle on and off as quick as you can until it runs normally. Helpful in the cold too .
Posted on Jul 29, 2010
rycgl
  • 1545 Answers
SOURCE: how to put together a black n decker grass
No, it is not heavy duty enough to drive a blade. It should have cuttting line in it and it only can use up to .065" string (factory recommended).
Posted on Oct 12, 2010
rycgl
  • 1545 Answers
SOURCE: grass trimmer head keeps turning
On an Echo, this means that the clutch is staying engaged to the walls of the clutch drum. Either the clutch drum is loose and the clutch pads are catching it as it turns, or the idle on the engine is set too high and the centrifugal clutch is just opening enough to catch the drum and spin it. Check the clutch housing and your idle speed.
Posted on Jun 12, 2011
I need instuctions on how to put back the throttle assemble for a husqvarner 223L trimmer
Hello Ronny
I'm not fully familiar with that model however I have found a diagram that may help you. The image is a little small but it may give you an idea of the springs location.
May 12, 2014 | Husqvarna 223L
How does the spring attach under the throttle on husqvarna whipper snipper
What is the model number, I'll send you the Illustrated Parts List
Sep 17, 2011 | Husqvarna 28cc Gas Line Trimmer
Engine start procedure for grass trimmer 350 L x series
  • With the trimmer placed on a level piece of ground press the primer bulb about 10 times.
  • Open the choke.
  • Press the throttle and lock it in place with the lock button
  • Pull the start cord until the engine catches. It doesn't matter if it cuts out again.
  • Close the choke, and if the engine did cut out the first time, pull the start cord again. This time it should start and you can start trimming the grass. If it didn't cut out just close the choke and you're ready for trimming.
Apr 06, 2011 | Husqvarna Garden
I was given a grass petrol strimmer and the pill cord spring and cord are broke. can fix myself just need to know where to get parts. living in ireland
Really simple to fix, easily done yourself if you know wtah your doing. Parts are available from your local husqvarna dealer
Jan 27, 2011 | Husqvarna Forest & Garden 125c 17"...
325 X-L trimmer throttle doe not operate.
There should be a small recessed area off to one side inside the handle for the routing of the throttle cable...Look closely. The spring that controls the return on the trigger isn't too complicated either. It has to be held in place somehere on the throttle handle also and may have to be preloaded so there is tension on it when you install it..Look around closely in the area in the handle RIGHT above the trigger.
Jul 11, 2010 | Husqvarna Forest & Garden 125c 17"...
Husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
Mar 23, 2009 | Husqvarna Garden
Garden Logo
15 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
