Question about Maytag Bravos MTW6600T Top Load Washer
Washer has standing water & won't turn on - Maytag Bravos MTW6600T Top Load Washer
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
GE WSXH208V1WW
Usually when you have a washer that will not drain, first check if the drain hose is kinked or too high above the washer (8 ft is the limit of the washer pump). Next check if there is a blockage in your drain (often a stand pipe) or if the air can't get into the stand pipe. The final thing to check is for foreign objects in the pump to drain hose area that block the drain. (This requires getting into the pump and disconnecting the hose. Keep a bucket ready to catch the water that will pour out of the washer.)
GE has the manuals for many of their appliances on their support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click submit. The direct link to the manual for the WSXH208V1WW is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90256.pdf .
I hope this helps.
(at least my washer won't spin if the water can't pump out. On a few washers (non-high efficiency) the solenoid has failed to open for the pump to drain the water.)
Nov 22, 2011 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Our Hotpoint Aquarius dishwasher initially had the Eco & Prewash lights flashing & standing water inside. We then turned it on in the hope that the standing water would drain, which it did. It then...
Is it a dishwasher a washing machine or a drier? Washing machines don't have rotating arms and you said "I've managed to get the drier to drain"
I will assume it is a dishwasher in which case it sounds like your pump has failed.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
It flash 2 then 0 and it wont drain or spin the clothes
F20 error code indicates no water detected entering the washer. Be sure the drain hose is not down too far into the drain stand pipe & both hot & cold water is turned on & working.
Jan 18, 2011 | Maytag EPIC MFW9700S Front Load Washer
Front door locked & will not start anew load
Do a Reset. Turn off the washer if you can. Be sure you are not standing in water.Unplug the washer, wait a minute or so, then plug it back in.
Dec 19, 2010 | Amana Washing Machines
What does LF stand for in the display window?
Hi
Thanks for using FixYa. Error LF indicates long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Standing water in washer front load tub
Welcome to FixYa.
Based on your description you likely have a faulty inlet/water valve.
Here`s an easy way to confirm or dismiss whether it is the vavle or not.
1) First drain the standing water which presently exists.
2) Unplug the washer from the wall/power outlet and allow the same period of time to pass, if the unit has standing water in it afterwards you need a valve.
If it doesn`t have water in it afterwards then the valve is being energized when it is plugged in even when it should not...that indicates a faulty control unfortunately, but not very likely,
The valve is part # 8182862 and varies in pricing around $40 - $75. It should be available at most brick and mortar appliance part locations or if you prefer on-line shopping try "searspartsdirect.com" "repairclinic.com" or "appliancepartspros.com" to name a few.
To swap out the valve simply follow these steps...
**Unplug the unit from the wall before attempting any repairs suggested here...safety first**
1) turn off the water and unfasten the hot & cold fill hoses going to the washer.
2) remove the three screws along the back of the top panel and then slide the top panel back slightly and pull up. The panel should lift away.
3) in the left rear corner ( when observing from the front of the washer )you should now see the valve which will look like this...
4) remove the wires, carefully the harness has little release tabs which must be bent back slightly to pull the wire & harness off.
5) remove the hose to the dispenser assembly, a pair of pliers or visegrips works well here.
6) remove the screw on the outside back wall of the washer and pull the valve out, voila !
Reverse order to put the new one in and good job. You potentially saved yourself $200 or more for parts and labour.
Hope this answers your question but more importantly solves your problem.
Thanks for choosing FixYa for your repair solutiuons today. Let me know if you need further assistance.
Please take a moment and rate the soluytion provided for you as well as a testimony if you feel it warranted.
Good luck.
macmarkus :)
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Not spining- water standing can't get water to
If your washer is not spinning ! You first need to drain it. Then underneath your washer you will find your drive system. It will consist of drive belt, drive pulley or pullies and motor. Belt could have come off , if so check the condition before reinstalling, also some times from overloading the belt will spin on the pulley which will make it hot and thanks to the manufacturer the pulley is likely plastic. Parts supply shops best source for belts and possibly pulley though sometimes they want to sale you the whole motor with pulley which you don't need. If so uae internet to find your pulley probably under 10.00 dollars. Hope this helps.
Feb 23, 2010 | Kenmore 23822 Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
13 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
