Question about Mantis Tiller
Do the older MANTIS tillers have a shear pin?
Tiller does not turn when engaged
5 Suggested Answers
  • 124 Answers
SOURCE: Mantis 2-strke cultivator,split pins Australia
contact southern supply
company at 205-833-2525 or email them at
southern.supply@mindspring.com and I feel sure Jason or
someone there can help you.
Posted on Sep 14, 2009
  • 5 Answers
SOURCE: starter rope hard to pull on mantis tiller
Sounds like your engine may be seized up. Mine did the same thing and I had to replace the block. If any dirt gets past the air cleaner or if your fuel mixture isn't right it won't take long to lock it up. If you need info on where to find parts, let me know. Good luck.
Posted on Jun 27, 2012
SOURCE: MANTIS tiller 7225-00-02 starter cord won't retract
take the crank rope cover off and in between rope reel and cover there is a wind up spring either its broke or has come out of its slots.
Posted on Aug 16, 2012
mavrickmoose
  • 9 Answers
SOURCE: shear pin for mantis tiller
What are you asking?
Posted on Sep 24, 2012
Trouble shooting 4 stroke mantis tiller wont turn tines and its almost like its stripped but cant figure out what needs replacing?
There is a shear pin on the drive shaft that holds the tines. IT is most likely hidden inside the housing.
Aug 03, 2017 | Mantis Garden
Blades will not turn
Does the engine run? If it runs the gear is most likely stripped out. Or it is the shear pins on the shaft. Gear can be replaced most are plastic an replaceable. Some are hard to find. Not hard to do just takes a little time.
Mar 25, 2014 | Mantis Garden
Shear pin for mantis tiller
Sep 03, 2012 | Mantis Tiller
Husqvarna shear pins break within minutes
if we are speaking about the shear pins on the tines, the ground is the problem and you need to begin your first pass on a more shallow setting and progress to a deeper setting gradually. if we are speaking about the shear pins on the tires w/o engaging the tines then these should not be breaking and I recommend that the tiller be examined by an authorized dealer.
Jun 15, 2012 | Husqvarna Garden
Starts and runs but tines won't turn
check for a damaged gear or shear pin
Apr 25, 2012 | Mantis 2-Cycle Tiller
Own an older (1990's) American Yard Products model WER500 Weedeater rear tine rotortiller. The engine runs great but when I engage to til, the tines won't turn. The belt is fine and pulleys turn...
Yes, there are shear pins on the tines and on the wheels. Can you check to see if the belt actually moves when the pulleys turn?
May 13, 2011 | Garden
Just bought an older Mantis 2 cycle tiller. The tines engage when the tiller is started. Of course that makes it hard to start with the tines on the ground! I don't believe it was doing this when I...
if the idle is too high the tines wont stop due to the tiller tines are run by a "centrifuigual clutch" which means when you increase the throttle speed the tines will start to turn : there are 2 adjustments you can try,1) adjust the idle screw under the carburetor where the throttle adjustment and a triangle piece of metal touch(your throttle cable wire will be attached to this triangle) ,if the triangle and idle adjustment don't touch and there's a gap between these 2 pieces close the gap by adjusting the 10mm adjusting nut,this will correctly set the idle #2) adjust the idle adjustment screw talked about above till the tines dont turn with throttle set at idle or lowest speed setting
Mar 26, 2011 | Mantis 2-Cycle Tiller
Sep 13, 2009 | Mantis Little Wonder Tiller/Cultivator...
Would like to know what year this tiller would be.
replace primer bulb. If that's not the problem check the float in the carb for pin holes . check fuel lines and intake line
May 15, 2009 | Mantis Tiller
Mantis Tiller Logo
42 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
