Question about Acer P205H Widescreen LCD Monitor
SERVICE MANUAL P205H - Acer P205H Widescreen LCD Monitor
Trying to hook up xbox 360 to computer monitor
Unless you monitor is HDMI capable I don't think it is possible without some sort of adapter.
http://godora.hubpages.com/hub/How-to-Connect-Your-XBox-to-your-PC-Monitor
Jan 19, 2014 | Acer P205H Widescreen LCD Monitor
Cannot view some webpages with acer p205h on ubuntu
This is unlikely to be a monitor issue, more likely a browser issue.
Please ensure you have the latest version of Ubuntu, Firefox and/or Google Chrome.
If this does not solve it, let us know which web pages you're having trouble with so we can take a look.
Jan 18, 2013 | Acer P205H 20 inch Monitor
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
I am using acer P205H monitor ,when i plug in it will start and shows acer symbol on the screen but goes blank as computer starts ,i checked all power cables they are OK ,and some switches are provided on...
that switches r made basically changing dvi to vga r vga dvi,if that switches r malfunctionig display goes to blank that means if u connect vga system will have dvi
Jan 30, 2011 | Acer AL1916W 19" LCD Monitor
Can anyone tell me what to use for cleaning an ace P205h monitor screen,,,, help,,,,, thank u
I always use Endust Anti static spray cleaner and always spray on a soft cloth first never on the screen. You can also use anti static wipes can be had anywhere. Never fluids direct like Windex on the screens. John
Jan 21, 2011 | Computers & Internet
My old del monitor all of sudden would stay on for 5 seconds then shut off. I got a new Acer P205H monitor and it says 'no signal'. I have a Dell Dimension 8300. Is it the monitor or the PC? Thanks for the...
sounds like a video card issue. sometimes they actually work loose if the one screw has been removed. Or it could be a cabling issue. If you or someone else has added a video card, then there are 2 places to plug the cable in the back of the tower, and one may not be active. So many possibilities:)
Aug 30, 2010 | Computers & Internet
My Acer P205H shows up for 1-3 seconds before showing a black screen. Connected DVI Cable but is there a need to connect vga too?
Depending upon the video port/s you have on the graphics card, you need to connector one video cable, either the DVI or the 15pin DSub to the monitor.
Sep 12, 2009 | Acer AL1916W 19" LCD Monitor
Display coming for 2 sec and then it goes off
Does it work well with other computers?
If you are connecting to a laptop, try switching display modes (like you would do for a projector)
Sep 03, 2009 | Acer AL1916W 19" LCD Monitor
Acer P205H Widescreen LCD Monitor Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
