Question about Sony Rmyd034 Remote Control
HOW DO I OPEN THE BATTERY COMPARTMENT ON SONY REMOTE RM-YD034
  • 23 Answers
SOURCE: it is broken. I have sony integrated remote commander RM-AV3000 .Need codes
what is a mySTR-DE698? but more generic, like brand and what it does. TV or DVD etc...
Posted on Oct 15, 2008
SOURCE: Code for Sony RM-V310A remote.
How do I program sony universal remote RM-V310A for a polaroid flat screen TV
Posted on Sep 09, 2009
SOURCE: how can i open my sony rm-ed009 remote control
insert wide flat blade (such as a wide flat bladed screw driver) into seam along one side. Twist carefully until seam starts to prise apart - carry on until you hear the "crack" of the press-tabs coming apart and repeat along the the length of the seam until you can carefully pull it apart.
Posted on Jan 02, 2011
  • 22 Answers
SOURCE: Sony RM-X151 remote control battery
If you look on the bottom edge of your remote you should see a little compartment that can slide out,then replace the battery(making sure it goes in the same way it came out!) slide the compartment back in the same way it came out and there you go!!!new battery,Good Luck!!
Posted on Sep 20, 2011
SOURCE: Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Posted on Nov 02, 2013
Hi, My sony remote failed recently Model
There is some locks on its upper and lower case. You can locate it by its side slits.
Oct 06, 2013 | Televison & Video
How do you replace batteries in a sony rm-sp350 remote
On the back of the remote, press the battery compartment cover where indicated and slide the cover off. It may be difficult to remove
Dec 02, 2012 | Televison & Video
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
You are done.
Apr 01, 2012 | Sony Rm-yd035 Remote Control
Sony RM-X151 remote control battery change. I cannot find out how to change the battery and what sort of battery it requires.
Sep 20, 2011 | Sony RM-X151 Remote Control
How do I remove the back of the remote control for a Sony TV? The model number is RM-ED002. I have located two small screws in the battery compartment but removing them doesn't seem to be enough to do the...
The two screws inside the battery compartment would not really hold the case together. Try using two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous.
Aug 22, 2010 | Sony RM-Y132 Remote Control
How can i open my sony rm-ed009 remote control
Feb 11, 2010 | Sony Televison & Video
How to fix a Sony Tv RM-YD026 remote after getting milk in the buttons
take batterys out then take out the little screws in battery compartment pry open the two halfs clean the board and buttons and let dry dont wipe the carbon off it is the main part of the switch for the buttons just clean with water and let dry
Oct 20, 2009 | Sony RM-YD023 Remote Control
How to open remote control Sony RM-Y181
There should be small screws (usually phillips head) at either the top, bottom or both ends of the back of the remote. Unscrew those and pry loose. If not, they will be under the batteries, inside the battery cover.
I assume that's what you mean by open?
:D
Aug 10, 2009 | Televison & Video
Sony Rmyd034 Remote Control Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
