Question about Altec Lansing Audio Players & Recorders
How to pair with ipad - Altec Lansing Audio Players & Recorders
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
Dec 05, 2016 | Radio Communications
Pair to iPad
Till now I did not know you could pair a mouse to an iPad. When someone is selling mice you can connect via bluetooth, they will give you the manual to. I hope you know, the iPad is not a computer on which you can connect lots of things. Only when Apple allows you to put anything on, or connect via bluetooth, it can work. Not when you think it should be great.
Because Apple made it possible to connect their key board to the iPad, you now can buy third party keyboards that work with the iPad.
Jan 30, 2015 | Ckeyin Mini Optical Bluetooth 3.0 Wireless...
I can't pair my shb4000 with my ipad
If your headset is compatible with the iPad, it should be paired like Apple describes on it website.
Follow the instructions
Using Bluetooth headsets and keyboards with iPad
Dec 27, 2014 | Philips SHB4000WT Bluetooth Stereo Headset
How do I pair my iPad as the second device
Make sure that the headset is not paired with the iPhone (turn off Bluetooth on your iPhone temporarily). Follow the same procedure you used to pair the iPhone, but this time with your iPad.
Dec 26, 2014 | Radio Communications
How to pair bluetooth keyboard with ipad mini?
Hi Douglas.
1. Switch on BlueTooth on your keyboard.
2. Enable BlueTooth on your iPad.
3. Search for devices on your iPad.
4. Press button if available on keyboard to get discovered.
5. Select keyboard when shown in devices list.
6. Enter pairing code sometimes 0000 or 1234.
7. Use and enjoy.
Hope this helps!
Here is the Apple site instructions:
Here is another that explains how to do it on a MAC, might give you some clues as well:
Bluetooth How to set up your Apple Wireless Keyboard
Here is a good independent site, maybe start here:
iPad How to pair connect any bluetooth keyboard
If you prefer to watch how to do it on YouTube:
How to Connect Pair Bluetooth Wireless Keyboard to your iPad
Nov 18, 2014 | Mini Cars & Trucks
My speaker does not connect to my ipad
The speaker has to be paired with your iPad before it will work. Check your documentation on how to put your speaker in "discoverable" mode long enough for the iPad to find it. If you have previously paired your speaker and it at one time did function is your iPad, make sure that Bluetooth is turned on on the iPad. Also, check the batteries on the speaker if it has previously functioned with your iPad...
Jun 21, 2014 | iLive Bluetooth Speaker System
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
Ipad and beikin keyboard
You will need to enable bluetooth on your iPad and then pair the keyboard to the iPad. Try the following:
  • On your iPad, tap the settings icon from the Home Screen.
  • Tap on General.
  • Tap on Bluetooth.
  • Toggle Bluetooth to On
  • Turn on the Belkin keyboard.
  • The keyboard will show up under Devices on the iPad.
    Select Belkin Bluetooth Keyboard.
  • A code will appear on the screen.
    Enter this code on the keyboard and click Enter.
A message will pop up when pairing is successful. If pairing fails, repeat the steps above. If you're still unable to pair the two leave a comment and I will help further troubleshoot.
Hope that helps!
Jan 15, 2014 | YouTube Videos
I CAN'T PAIR WITH ipad OR PHONE
Among the convenient features of the Apple iPad is the ability to pair the iPad with Bluetooth devices.
Bluetooth devices allow the iPad to interact with wireless accessories including headsets and keyboards.
Like most things related to the iPad, connecting an iPad to a Bluetooth device a quick process.
Refer to the device's instruction manual for directions to make the Bluetooth device discoverable.
Typically, this involves holding down a button for a few seconds.
To pair an iPad and a Bluetooth device, the Bluetooth device must be discoverable.
Turn the iPad's Bluetooth capability on.
Go to the settings menu on the iPad by tapping the "Settings" icon on the iPad home screen.
Tap "General" from the left panel and then "Bluetooth."
Once you are in the Bluetooth screen, slide the "On/Off" switch to "On" to turn on Bluetooth.
Select the device you wish to pair with the iPad from the list of discoverable Bluetooth devices that appears on the screen.
Depending on the device, a password may be required.
Refer to the Bluetooth device's product manual for this password.
Hope this helps.
Nov 23, 2012 | Computers & Internet
Can my motorola hH695 be paired to my iPad?
Hi, this instructions works on some iPads, you can try it on yours.
How to Pair A Bluetooth Device With The iPad
Among the many convenient features of the Apple iPad, the ability to pair the iPad to any Bluetooth device is very convenient.
Bluetooth devices allow your iPad to interact with devices ranging from headsets to computers without the use of wires.
Like most things related to the iPad, connecting an iPad to a Bluetooth device is easy. Follow these simple steps to do so.
Instructions
Things You'll Need:
* iPad
* Bluetooth Device (headset or other)
First, in order to pair the iPad to a Bluetooth device you need to make sure the Bluetooth device is discoverable. Refer to the instruction manual for the device (which you can find online usually if you lost it) on how to do this.
Typically, it just involves holding down a button for a few seconds.
Next, you need to turn the iPad's Bluetooth capability on. Go to Settings by touching the Settings App icon that looks like gears.
Within Settings, select General and then Bluetooth. Once you are in the Bluetooth screen, press the on/off switch to turn Bluetooth on. Make sure it reads "on".
Once you turn on Bluetooth, you should see the discoverable Bluetooth device show up on the screen as part of a list. Select the device you wish to pair with the iPad.
Depending on the device, it may prompt you for a password. Refer to the Bluetooth device's product manual for this password.
Tips & Warnings
A white Bluetooth icon on the top of the screen indicates a device is connected to the iPad
A gray Bluetooth icon on the top of the screen indicates Bluetooth is on but no device is connected.
Jan 09, 2011 | Motorola Mobility H695 Bluetooth Headset
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
