Question about Whirlpool GHW9300 Duet Washer
Water was not on, so I pushed the pause/cancel to stop cycle. Machine will not unlock. I have unplugged it, turned the water hoses on and replugged the machine. The timer flashes but does not restart. The pause/cancel button does not click or unlock the door.
  • 76 Answers
SOURCE: washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Posted on Mar 22, 2007
fanny
  • 146 Answers
SOURCE: Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Posted on Nov 06, 2007
jsrock516
  • 5911 Answers
SOURCE: help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Posted on Aug 27, 2008
aborcass
  • 2651 Answers
SOURCE: timer light keeps flashing
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
Posted on Jan 25, 2009
JULIANFIX
  • 975 Answers
SOURCE: Front loader with F02 problem
CHECK THE DRAIN MOTOR PUMP it could be clogged, need to open washer , locate drain motor , youll see the drain hose connected to it , inspect , clean and replace , AJ
Posted on May 18, 2009
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    Code problem on the machine is F20
    "F20" on display
    (Water Inlet Problem-no water or insufficient
    water supply)
    Select PAUSE/CANCEL twice to cancel the cycle
    Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
    Are screens at inlet hose connection to washer
    clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
    also, those flood prevention hoses they sell you don't work well with front load washers
    Jul 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    FH appears
  • 2
  • 3
  • 4
  • 5
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    Error code HF
    Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
    Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
    Getting F20.
    “F20” on display
    (Water Inlet Problem—no water or insufficient
    Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    I'm getting a F20 code?
    “F20” on display
    water supply)
    Nov 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    My duet washer has an error code f20...what does this means?
    not enough water going to the machine..
    “Spin” and “Wash” (HT “Rinse” and “Cycle
    Complete”) illuminated or “F20” on display
    water supply)
    Aug 19, 2009 | Whirlpool Duet WFW9550 Washer
    F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
    Hi!
    “F20” on display
    Do rate the solution.
    Thanks
    Rylee
    Feb 08, 2009 | Whirlpool WFW8300SW
    Control lock light will not go off.
    Do you have any error codes?
    Does water remain in the washer after the final spin?
    If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
    Is the door locked and the Add A Garment light on?
    If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
    Is the door locked and the Add A Garment light off?
    If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore Elite He3t front load washer - error code reads H & F
    the F code is a puwer outige. This is how to fix
    Select PAUSE/CANCEL twice to cancel the cycle. Select
    DRAIN & SPIN if there is excessive water in the washer.
    for service.
    This is what an HF code is.
    "FH" (Water Inlet Problem--no water or insufficient water
    supply)
    Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    Dan Webster
    Dan Webster
    Sal DeAngelo
